Hybrid frame differences
Zombie
#1 Post by Zombie » Sun Oct 09, 2016 1:40 am
Does anyone know the difference between the Apriillia RS250 frame and the LD variant of it? I want to build a hybrid using the Fast from the Past kit, but it says that its not for the LD variant of the frame. What is different? Does anyone make a cradle kit for the LD?
-Z
evan_calgary
Re: Hybrid frame differences
#2 Post by evan_calgary » Sun Oct 09, 2016 1:52 am
If you contact fast I believe the do have a kit for the other variant. Check the Aprilia AF1 site for more info. There are likely 10 builds on there using RZ bottom end.
RDZombie
#3 Post by RDZombie » Mon Oct 17, 2016 8:46 am
The LD frame upper/ front cradle mounting bolt holes are drilled differently and need to be re-drilled to fit the non LD cradle
84 KR RZ350
84 RZ421
RZ500/FZR400 hybrid STILL in the works
74 GT750
02 RS250
91 NSR250
