Rz350 ypvs frontbrake problem
Jimmye
#1 Post by Jimmye » Fri Nov 18, 2016 10:57 am
Hey all! Have problems with bleeding my front brakes. It looks like I got out all the air but still spongy brake. No leaks in the system.
Any suggestions? :smt026
/Jim from Sweden
Future setup on my RD 350 1984 RD350LC2 YPVS:
Mick abbey steel pipes with carbon fiber silencers
Keihin pwk 28mm carburetors
Modified airbox
Lightened flywheel
Zeeltronic ignition
Ported engine block
TSS ypvs valves
Wossner 65mm pistons
Welded crank
Re: Rz350 ypvs frontbrake problem
#2 Post by RuZty » Fri Nov 18, 2016 3:04 pm
It is hard to get all of the air out of the master cylinder. I've always removed it from the bar and tilted it to allow the air to escape to the reservoir. Others have recommended tying the lever back against the bar overnight, but I haven't tried it myself.
#3 Post by hondaror » Sat Nov 19, 2016 12:49 am
Have you cracked all the banjo bolts in the system to bleed them? Have to ask that.
two-stroke-brit
#4 Post by two-stroke-brit » Sat Nov 19, 2016 1:17 pm
the mityvac makes it a lot easier on your own.
whyzee79
#5 Post by whyzee79 » Sat Nov 19, 2016 1:56 pm
Rubber band the lever tight overnight and then check.
