It is currently Wed Jun 20, 2018 6:10 pm
Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: R6 rear shock conversion
PostPosted: Thu Mar 09, 2017 2:37 am
I'm looking to do the R6 rear shock conversion, can someone post a link to get this done. I'm sure there is several topics on hear.
1987 RZ350 Stock
1985 RZ350F basket case
1985 RZ500 Stock
PostPosted: Thu Mar 09, 2017 4:06 am
Moderator
Moderator
I have good photos of the whole process done on my bike. If you want them just let me know.
Online info here http://www.scooterhelp.com/RZ_help/upgr ... sting.html
And here http://eastcoastrzs.tripod.com/id2.html
The bushing were coming from McMaster-Carr, but they won't ship to Canada, at least not when I did mine, so you need an alternate source for the bushings. John at Economy Cycle has the bushings now. He can also supply the shock with bushings https://www.economycycle.com/product-ca ... uspension/
If you do the mod you will need a longer side stand. I used one from a Ducati 1099. Worked perfectly.
PostPosted: Thu Mar 09, 2017 7:39 am
Pretty sure Jon has a good description on his site too, Rob
PostPosted: Thu Mar 09, 2017 8:05 am
I have an entire shock ready to drop in if you're interested.
The only change necessary on your bike would be to cut a piece of the shock mount so the reservoir clears. It's a semi circle the size of a 17mm chrome socket
PostPosted: Thu Mar 09, 2017 9:07 am
I do indeed Howard, http://2smoked.com/Yamaha_RD_%26_RZ_upg ... _YPVS.html
My Projects:
PostPosted: Thu Mar 09, 2017 9:19 am
There is also this post; viewtopic.php?f=2&t=13852
installing a 2015 R1 shock. Similar spring rate and arguably better shock, if only for the fact that it will be far newer. The length is similar to the R6 so I don't think it is necessary to shorten it as the OP did unless you can't touch flat footed with the stock shock. It would be the same effort to install as the R6 shock, unless you buy Justins already modded one. I've had an R6 shock on mine for 15 years and it still works well.
PostPosted: Thu Mar 09, 2017 9:24 am
Ok perfect guys. I have the shock already and just need to round up the bushing. I will try EC for those.
I will post some pics when I get it done, at the pace I have been doing anything with the bikes these days it maybe a while!! Too dam busy between work and 3 kids!
1987 RZ350 Stock
1985 RZ500 Stock
PostPosted: Wed Mar 15, 2017 8:15 pm
It took a buddy and me an afternoon. We both have two kids. Does that count?
Nice upgrade, even better with an FZ swing arm and rear wheel. You'll have a completely (comparatively) modern rear end after that!
PostPosted: Sat Apr 01, 2017 7:35 pm
Ok, got the bushings from EC and installed them in the shock. I modified the mount and installed the shock. The only issue is the lower collar is REALLY tight in the new lower bushings. The collar was rust free and is good condition. Anyone else have this issue, now I'm worried movement of the shock will be hampered as there is no way the collar can turn in the bushings.
1987 RZ350 Stock
1985 RZ500 Stock
PostPosted: Sat Apr 01, 2017 8:11 pm
Weird, mine were fine.
My Projects:
PostPosted: Sat Apr 01, 2017 8:52 pm
I may need to get a bit turned off the bushings to make it right? My bike is a 1987 F2, may be there is a slight difference is the collar over the earlier bikes?
1987 RZ350 Stock
1985 RZ500 Stock
PostPosted: Sun Apr 02, 2017 1:22 am
Problem solved!
1987 RZ350 Stock
1985 RZ500 Stock
PostPosted: Sun Apr 02, 2017 9:38 am
All collars were the same AFAIK. glad youre sorted Rob.
My Projects:
PostPosted: Sun Apr 02, 2017 10:16 am
Rob i had same problem with mine,while you have the sanding drum out you can use it to trim up the chain guard after you do the cutout.
PostPosted: Sun Apr 02, 2017 10:28 am
I have yet to cut out the chain guard. I feel a bit bad to cut it, but the new shock will be well worth it I'm sure.
1987 RZ350 Stock
1985 RZ500 Stock
