It is currently Wed Jun 20, 2018 6:27 pm
Post new topic Reply to topic  [ 9 posts ]
PostPosted: Fri Mar 10, 2017 11:14 am
I installed some rearsets from Slipstream on my 1973 RD350 and I'm trying to figure out how to setup a new mount for the rear brake light switch. Slipstream is trying to get me some customer photos, but no luck so far. Does anyone have any ideas?
http://slipstreamcycle.com/products/yam ... 0-rearsets
Thanks,
Scott
PostPosted: Fri Mar 10, 2017 6:54 pm
I would fab a bracket that sits above/behind the cable for the switch itself. Drill a tiny hole for the spring on the cable connector.
PostPosted: Fri Mar 10, 2017 8:15 pm
Do you mean to weld the bracket to the frame or to the swing arm? Can you mark up a picture of what you mean?
Thanks!
PostPosted: Fri Mar 10, 2017 10:02 pm
You could always add a pressure switch banjo bolt and operate it that way.
PostPosted: Fri Mar 10, 2017 10:05 pm
No pressure switch...it's not hydraulic brakes
PostPosted: Sat Mar 11, 2017 12:23 am
Yeah, that would matter. Sorry I didn't look closer at the application.
PostPosted: Sat Mar 11, 2017 11:15 am
Online
I was about to say the same thing. Sorry, no help here. :smt009
1983 rwb RZ350 Canadian stock (exc toomeys)
1985 rwb RZ350NC vm30,pods,porting,spec2 pipes
1985 yb RZ350 rat driver,fz/fzr parts,fox shock,vm30,pods,porting,toomeys
1985 RZ350 black? fz/fzr susp (in process)
more RZ350s on hold
1985 RZ500 (done, yah sure)
PostPosted: Sat Mar 11, 2017 2:07 pm
I meant a bracket on the rearsets themselves that's bolt on to hold the brake switch. Think what's on the frame bolted to the rearsets. I would be horizontal though.
PostPosted: Sun Mar 12, 2017 9:30 pm
Moderator
The front brake master cylinder on rd and rz etc. have a little microswitch to activate the brake light.
Wondering if you could use one of those, maybe in the area of the adjustable stop bolt on your rearsets?
Or a newer Yamaha one like this:
http://www.ebay.com/itm/1985-YAMAHA-FZ750-FRONT-BRAKE-MASTER-CYLINDER-BRAKE-LIGHT-SWITCH-/330840160431?hash=item4d079c38af:m:m6bHkVAG7v8SGqEAtzGl0zw&vxp=mtr
79 RD400F Daytona Special
81 RD350LC
89 TDR250
75 Kawasaki H1 500
77 Can-am Tnt250
