1973 RD350 Rear brake light switch mount with rearsets-HELP
Posted: Fri Mar 10, 2017 11:14 am
by Badfish67
I installed some rearsets from Slipstream on my 1973 RD350 and I'm trying to figure out how to setup a new mount for the rear brake light switch. Slipstream is trying to get me some customer photos, but no luck so far. Does anyone have any ideas?
http://slipstreamcycle.com/products/yam ... 0-rearsets" onclick="window.open(this.href);return false;
Thanks,
Scott
Re: 1973 RD350 Rear brake light switch mount with rearsets-H
Posted: Fri Mar 10, 2017 6:54 pm
by justind97
I would fab a bracket that sits above/behind the cable for the switch itself. Drill a tiny hole for the spring on the cable connector.
Posted: Fri Mar 10, 2017 8:15 pm
by Badfish67
Do you mean to weld the bracket to the frame or to the swing arm? Can you mark up a picture of what you mean?
Thanks!
Posted: Fri Mar 10, 2017 10:02 pm
by RuZty
You could always add a pressure switch banjo bolt and operate it that way.
Posted: Fri Mar 10, 2017 10:05 pm
by Badfish67
No pressure switch...it's not hydraulic brakes
Posted: Sat Mar 11, 2017 12:23 am
by RuZty
Yeah, that would matter. Sorry I didn't look closer at the application.
Posted: Sat Mar 11, 2017 11:15 am
by kpke
I was about to say the same thing. Sorry, no help here.
Posted: Sat Mar 11, 2017 2:07 pm
by justind97
I meant a bracket on the rearsets themselves that's bolt on to hold the brake switch. Think what's on the frame bolted to the rearsets. I would be horizontal though.
Posted: Sun Mar 12, 2017 9:30 pm
by 2smoke
The front brake master cylinder on rd and rz etc. have a little microswitch to activate the brake light.
Wondering if you could use one of those, maybe in the area of the adjustable stop bolt on your rearsets?
Or a newer Yamaha one like this:
http://www.ebay.com/itm/1985-YAMAHA-FZ7 ... zw&vxp=mtr
