What is the size of the bushing to get at mc master-Carr for the R6 rear shock on the rz
Shock bushing
Re: Shock bushing
You need two 6659K36 Metric SAE 841 Bronze Flanged-Sleeve Bearing for 18 mm Shaft Diameter, 22 mm OD, 18 mm Length
You need two 6659K41 Metric SAE 841 Bronze Flanged-Sleeve Bearing for 20 mm Shaft Diameter, 24 mm OD, 16 mm Length
Re: Shock bushing
justind97 wrote:You need two 6659K36 Metric SAE 841 Bronze Flanged-Sleeve Bearing for 18 mm Shaft Diameter, 22 mm OD, 18 mm Length
Re: Shock bushing
thanksshilo123 wrote:justind97 wrote:You need two 6659K36 Metric SAE 841 Bronze Flanged-Sleeve Bearing for 18 mm Shaft Diameter, 22 mm OD, 18 mm Length
