Missing center tank rubber support Rd350 F2 1990
kjellz
#1 Post by kjellz » Sat Apr 14, 2018 5:56 am
Hi
As the photo indicates theres seems to be missing some sort of peg or pin that will locate the center under tank rubber support?
Can anyone help me find out what is missing?
I have found the rubber damper is as a spare part, but the peg seems not to be. Is it glued on? What material and dimension should it be in case I can replicate it?
- Previous owner tried to mend it by adding some rubber foam it seems.
Tank peg.jpg (108.12 KiB) Viewed 1499 times
Thanks for any input.
Kjell
RD350 YPVS 1990
AlexG
Re: Missing center tank rubber support Rd350 F2 1990
#2 Post by AlexG » Sun Apr 15, 2018 11:01 am
kjellz wrote:Hi
Kjell
Hi: there is a steel short pipe with two rubber stoppers at the ends. Those stoppers engage the U-slots on either side of the tank center tunnel. Your frame is missing that pipe. It is a weld job.
#3 Post by JonW » Sun Apr 15, 2018 6:26 pm
The top pics on this page (its my 85 F1 rebuild) show it:
http://2smoked.com/Yamaha_1985_RZ350_YP ... ation.html" onclick="window.open(this.href);return false;
Zedixe13
#4 Post by Zedixe13 » Sun Apr 15, 2018 10:33 pm
86-90 tank are supported on each side by a small bracket that bolt to the frame , look just under the left spark plug wire and you can see where the tank bolt . Nothing is missing on your frame .
justind97
#5 Post by justind97 » Mon Apr 16, 2018 9:23 am
You are missing a post, yes. I can't remember if it's welded, but I think it is.
If you look at the bottom of the tank, it looks like a fork. The post sticks up from the frame, has a rubber mount.
Take a look here, zoom in to this frame.
https://www.ebay.ie/itm/Yamaha-RD-350-Y ... Swc69alQyC" onclick="window.open(this.href);return false;
#6 Post by JonW » Mon Apr 16, 2018 9:25 am
I see it now, its an 86-on model, yes you're still missing something and its a small internally threaded post on my frame. I guess Im also missing the bits that screw to it just like you are, damn the 86-on model tank fixings are complicated! :(
kjellz
#7 Post by kjellz » Mon Apr 16, 2018 1:20 pm
justind97 wrote:You are missing a post, yes. I can't remember if it's welded, but I think it is.
Thanks, thats what I was looking for.
Need to get hold of one of those rubber things next. Tempted to just drill through and tap for fixing it...
Kjell
RD350 YPVS 1990
#8 Post by JonW » Mon Apr 16, 2018 6:06 pm
That would work I think if youve enough steel left to get a good fixing.
