R6/rz350 swing arm conversion
addicted to relics
Re: R6/rz350 swing arm conversion
#16 Post by addicted to relics » Sun Aug 19, 2018 5:53 pm
Wow I just look at the R6 swinger and its like 4 inches wider than the rz I don't even know where to begin cutting and widening to fit it to my frame so its a bust ill just keep with stock swingarm and put my $$$ somewhere else as its stock and it works I have other issues to spend my valuable earn $$$ on likiw wiring
anyone using ultima wiring harness kit? (maybe ill start another thread on it as it liiks simple and using a solid state battery is in my plan)
Cheers Bryan
RuZty
#17 Post by RuZty » Sun Aug 19, 2018 9:27 pm
MK wrote:RGV250: Either gullwing or straight work both. Use the adapter plates from the net incl the stock linkage. Get a "RGV" shock build/setup for new bike+rider weight.
For the front end I would prefer the R6 over the RGV.
6 kg lighter and better suspension / adjustments.
150 or 160 tire is just fine. I prefer the 160's as there's more choices.
Like this;
Tires are Metzeler M7RR, Penske shock setup for the bike.
giron
#18 Post by giron » Mon Aug 20, 2018 10:14 pm
or
1985 RG500(Walter Wolfe)
1984 IT490
1985 RZV500R
1997 VFR750
1992 FZR1000
RGV500
TZR500
TZR350
1990 RZ350
1971 Porsche911S
Crimsondevil
#19 Post by Crimsondevil » Fri Nov 16, 2018 9:13 am
Hi, here is my R6 swingarm/rim conversion :-)
- Swingarm pivot machining to raise down the wideness
- New uper shock linkage (tig welded)
- Inner area of the frame modified.
If you want to read the whole story --> viewtopic.php?f=5&t=15260
