Rotor bolts
- tropical snowman
Rotor bolts
I've managed to confuse myself, I thought when putting in disc bolts that you always use Loctite but I read online that you should use copper grease?
which is it? Loctite or copper grease?
cheers
Matt
cheers
Matt
Living in Paradise!!
- tropical snowman
see what I mean.... good arguments for both, I have to admit that I think the blue loctite is the way to go, I certainly don't want a bolt to come loose!
I think if it was a race bike that got lots of attention and the rotors are taken off occasionally then the copper grease is probably better but I can't ever imagine having to take the rotors off again.
thanks for the input
Matt
Matt
I use a ton of titanium so I have to use the anti-seize compounds. It keeps the different metals from galling or seizing together. If you are only using steel I think loctite would be fine. I would only use blue though as the red needs heat to break it loose and there is too much rubber, paint, fuel, oil etc. for using heat. Michael
Matt,
Like MBoyett220 said, only difference is 95% of the bolts on my RGV are
"Ti" and I use blue loctite not anti-seize. The loctite works very well as
a lubricant for the treads and helps prevent galling with dissimlar metals.
Anti-seize is good stuff, if your anal about torquing be neat when applying
to much can actually effect your torque reading. In my real job we use
a substance called Kyrtox on alum. and stainless fittings, works very
nice, but unfortunatly it's not available to the general public.
Maybe not at a store near you but available online .... cheap too ...
http://www.vacuumoil.com/krytoxgrease.htm
1) 1984 Yam RZ350 w/ Spec II chambers, Zeeltronic, and K&N pods ... stock otherwise
2) 1984 Yam RZ350 awaiting '06 GSXR600 USD front, FZR400RR rear, & rev cyl's
- tropical snowman
Ok, I figured out what I want to do, I will use the copper grease because I want to get some titanium bolts eventually.
RGVSteve can you post some pics of your bike please?
On another note, I've decided that the 'worlds rattiest RZ' will now be wearing an Aprilia RS250 frame and swinger and have a cheetah kit...finally I've made a decision!
Does anyone know where the best place to get Ti bolts is? I found some in the UK but rotor bolts were about $200-250 for the set of 3! I also want to get some for the front fender and most other places on the the bike.
And thanks for all the advice
Matt
Matt
Cheetah kits are fun....
Remember tho that if ya use anything over the 421 kit means you need to have your cases machined,Personally I dont see the point in spending the dollars to use the kit and only end up with a 420 at best....Also,Make sure ya use the cheetah and not the cub/supercub.
I hope Mr Steve doesnt mind me posting a link to his site....
http://www.rgvsteve.com/
A lil job he did 4 me :)
http://www.rzrd500.com/500phpBB3/viewtopic.php?t=7363
Ive been dealing with the two masters(Rgv Steve +Steve Murphree)
for a little while here in the USA,I would highly HIGHLY recommend them both! - I have looked at stuff from Mick Costin as I have a ton of AUS mates but his stuff is a lil pricey,UK very likely the same way....If ya need help here shipping to you in Aus let me know as generally im sending stuff there weekly anyways and would be happy to add yer stuff into the equation :) - I can certainly help with the cheetah stuff as im a trinity racing dealer / Yamaha dealer to boot :)
MB
MB
How's that going to work Force? Looks like it will be an horizontal underframe shock arrangement. Will the arm have struts to a 180 deg rocker above swinger strutted to a 90 deg rocker below to compress the shock?
BTW ... very nice welds & machining
xen-uno,
Force's swingarm will work exactly like the stock arm. "A" brackets are
made and welded in same location relative to swingarm pivot bolt and
lower frame pivot assemble attach bolt just like the stock swingarm, so
unless something on my jig changed, it should work nicely.
I do have a question if I may, have you had a chance to meassure the
length of the pivot tube on your 400RR arm, if so would you share that
info.
Thank You
info.
Thank You
