FZR400 First Impressions
We love ALL motorcycles - post your non-2T custom build here!
evan_calgary
Post by evan_calgary »
So I bought a FZR400 some time ago with a 600 motor in it and just got out for my first ride on the bike. I was very amazed, the thing is tiny and goes awesome. Handling is amazing. Overall its really a great bike, tight and steady yet very compliant. I am really used to the modern supersport package which is similar in size but due to the riding position of the 400 it just feels mini. Still need some jetting work but very impressed so far. Highly recommended!
Re: FZR400 First Impressions
Post by MK »
Just this weekend I spoke to a friend who bought one as a donor for a hybrid.
He's as fond of it as you are though he only has the 400 Cc. engine.
kpke
Post by kpke »
That is a cool bike Evan! It looks like fun to me. The 600 engine is a bolt in Into that chassis correct?
One parked next to my bike up at Alice's on Sunday.
We were trying to figure out why that FZR600 had an aluminum swingarm. Somebody mentioned it might be a 400. Then the dude walked up and said it was. This was a very clean example.
Enjoy yours. :smt023
Post by MK »
And he said the 400 would have an aluminum frame as well, wheras the 600 has a deltabox in steel ...
evan_calgary
Yes, the 400 got all the fun alum bits but for some reason the subframe is still STEEL and weighs a ton. The 600 was a dog of a bike due to the steel everything. The 400 with a 600 in it is torquey and all around good times.
tacky1
Post by tacky1 »
Nice one for sale on Fleabay... http://www.ebay.com/itm/222166254290?rmvSB=true" onclick="window.open(this.href);return false;
evan_calgary
I am going to have to hunt down someone with a stock motor in one to compare. Quite curious. The 600 motor goes like mad and actually has way more torque than I expected.
vonzipper
Post by vonzipper »
Evan you have the best of both bikes, I've owned both models in the past, the 600 had the better motor for obvious reasons and the 400 had lighter aluminum frame and swinging arm ect. The 400 with its original motor you had to rev it to the moon to get any sort of power from it, were as the 600 had way more torque low down and through out the range. After riding the 600 motor you will be disappointed with a stock FZR400/ motor.
90 RZ350 Track bike.
86 RZ350 Stock daily runner.
84 DT200
84 RZ500
evan_calgary
Thanks for the comparison. I was very surprised with the torque of the 600 in the 400 chassis. Pulls right from 4000. It doesn't hit that hard as you rev it out so either they had rather linear power delivery (not used to after riding modern 600's) or I need to do some jetting work. The pipe is still a bit sooty so I think there is a good chance some jetting work is required.
vonzipper
Post by vonzipper »
The power is very linear and you have to also rev it to the moon to make power on the top end.
84 DT200
84 RZ500
vonzipper
Post by vonzipper »
But its one of the smoothest in line four motors .
84 DT200
84 RZ500
evan_calgary
Any idea what the redline is on the 600 motor? My tach goes up to 14k redline but not sure if that is correct for the 4 or 6...
vonzipper
Post by vonzipper »
It's not that high for the 600 tho, I think it goes up to 1150, will have to check when I get home.
84 DT200
84 RZ500
vonzipper
Post by vonzipper »
11500 red line on the 600Image
84 DT200
84 RZ500
evan_calgary
Yikes, I will need to double check which CDI the bike is running. I had it revving up in that range. These must have had rev limiters.
