Cheap and easy crack repair for plastic sidecover 84 RZ
75RD350rider
#1 Post by 75RD350rider » Wed Feb 24, 2016 1:03 pm
Found a small crack in my RZ LH sidecover cleaned it up good and used some 80 grit wet or dry tri-mi to roughen the surface per the instructions.
JB weld plastic repair 2 part epoxy LH side cover repaired $6.00 at Ballmart for the JB and Bob's your Uncle. Easy to use and once sanded smooth primed and painted the repair will be invisible.
Tim Steele in Front Royal, VA
75RD350rider
Re: Cheap and easy crack repair for plastic sidecover 84 RZ
#2 Post by 75RD350rider » Wed Feb 24, 2016 1:04 pm
Body work will be taken to the painter today.
evan_calgary
#3 Post by evan_calgary » Wed Feb 24, 2016 8:23 pm
The JB and other 2 part epoxy repair kits are the way to go. Extremely strong. I prefer the more liquid product and usually use plastic grid material to add strength. Find it much better than any heat welding product,
spook
#4 Post by spook » Sat Mar 19, 2016 3:26 am
The same question came up about a year ago and John dubya suggested Testors liquid plastic cement for model aeroplanes.
#5 Post by JonW » Sat Mar 19, 2016 8:40 am
The best stuff is really the products designed for the job, I have tried many of them with various rates of success but also various plastic cements including plumbing stuff. I have some Wurth to try next, just havent had a chance to try it yet, but I will as a friend sent me some. I usually weld with a soldering iron and bits of old fairing and that works well.
whyzee79
#6 Post by whyzee79 » Sat Mar 19, 2016 1:23 pm
I have also added a small piece of model airplane fiberglass cloth to the mix to strengthen it as well. The plastic glue makes a good resin. Works great on the backside of side cover.
evan_calgary
#7 Post by evan_calgary » Mon Mar 21, 2016 2:10 pm
I have been through quite a number of these products and the JB weld/Permatex plastic welder are better than the solder iron trick and possibly better than the actual plastic welder. The solder iron WILL give you extremely brittle plastic that WILL crack like fiberglass when put under any sort of strain after some time. The plastic welder also works to combine fiberglass patches with the original fabric. There is specific plastic mesh sold that is a better bet than adding fiber cloth to the mix.
