Hello
Has set the float height to 21mm without gasket. Have put the bike on the center stand.. run over drain hose up along the back of the carburetor.. then opens the drain screw and lands as approximately of the washers.
Look at the picture
Does it look correct?
Ron
Fuel level
Fuel level
- l.jpg (72.26 KiB) Viewed 1988 times
Re: Fuel level
Hi.
The correct level is this.
Regards.
Regards.
