How 2 purify fuel by removing the ethanol
Here is a vid that shows how to remove the ethanol (usual 10% content) to create pure fuel. Found this on the 2stroke World site for the DIY Youtube link. Mid way the vid appears to be stalled but it's not. Interesting method using a couple jerry cans and tubing. Appearently ethanol is a leading cause for pre-denotation. Anyone experince that due to the addition of ethanol?
https://www.youtube.com/watch?v=r_AJhtkOy2M" onclick="window.open(this.href);return false;
Re: How 2 purify fuel by removing the ethanol
That is excellent, and easy.
I use the pure-gas website to find stations that sell ethanol free fuel and skip this step.
I only put Shell V-Power in my bike, the only fuel I can find that has no ethanol in it (at least in Canada).
I use the V Power too, but nice to know we are not hooped.
- two-stroke-brit
its 75 miles to the nearest E-free Gas for me so i will be trying it.
I think I would put a small sample in a glass and make sure all the water is out.
Another alternative
- IMG-20160904-00816.jpg (87.96 KiB) Viewed 6075 times
About 10 miles from me there is the Firebird International Raceway. And across the street is a gas station that sells 100 and 110 octane racing (leaded) fuel at a drive up pump. About USD$8.00 per gallon.
But I would prefer 94 at most stations even though it's CND$1.59 per ltr. At least it's available in many places.
I guess it's Canadian envy, except for the cold and snow.
1971 Kawasaki F5a Big Horn
2013 NC700X
2013 NC700X
Went surfing on Dec 26 and I did not shovel one flake of snow last year (but we did have a monsoon season). Less mold in AZ or flu. 105 huh? Love to try a tank of that! I was advised I could get local av fuel that is appearently leaded. The 94 costs $22 Cnd for RD fill. I'm sure its cheaper below the 49th parallel or in a different province.
You can just run castor oil and not worry about it. Mineral oil wont mix with ethanol, but castor will. Plus it smells good! I run 93 octane with ethanol in it at 40.0:1 in my CR500 with castor and have never had a problem.
-Z
-Z
Do you castor in the injector or just premix? If I could run castor in the injector I'd be down with that, but not premixing.Zombie wrote:You can just run castor oil and not worry about it. Mineral oil wont mix with ethanol, but castor will. Plus it smells good! I run 93 octane with ethanol in it at 40.0:1 in my CR500 with castor and have never had a problem.
-Z
I premix, because the CR500 is a dirtbike without oil injection, but several companies like Klotz make castor that will work just fine through an injection system.
-Z
-Z
Oh, good to know. [WHITE SMILING FACE]
THIS.RuZty wrote:I only put Shell V-Power in my bike, the only fuel I can find that has no ethanol in it (at least in Canada).
