throttle cable compatability question
Will the Canadian or Euro Spec throttle cable with oil pump cable fit a US 84 RZ throttle tube and housing ? Furthermore will this cable operate VM 30 roundslides?
Tim Steele in Front Royal, VA
Re: throttle cable compatability question
Yes it will, Thats what I used on mine, Ordered one from GB and it works with my 28s perfectly.
COOL
Thanks!!
Thanks!!
I don't think it will work with the standard US carbs, but I only had to modify it slightly to go from stock 31K VM26 to PWK28's, so VM30 should be a snap. I think they were recently about $80 CDN at the dealer.
Oh, I did have to use angled adjusters on the carb tops to clear the frame...
These are the ones I used, Worked perfectly
http://www.ebay.com/itm/Mikuni-VM-Carbu ... dc&vxp=mtr" onclick="window.open(this.href);return false;
I think I have those or similar on my VM 30s now. They came from Spec II.
This is the cable I need ?
http://www.diablocycle.com/Yamaha-RZ350 ... Cable.html" onclick="window.open(this.href);return false;
That the one. Two carb and one oil pump.
Thanks!!! I just ordered it from Diablo. $52 shipping was bit much but you wanna play, you gotta pay as the saying goes
Diablo Cycle comes through .... they said it was an error and shipping is $27... Yay!!!
Tacky, thanks for the link to the adjusters. I ordered a set of those too.
Glad I could help :)
The new throttle cable is installed and preliminary rigging is sorted. I had to remove the barrels from the adjusters and the nuts on the bottom to get enough length for the 30s. In turn this messed up the throw for the oil pump cable solved with a spacer under the barrel to get the correct orientation back. Works like a champ. Pics will follow.
Deadly, Glad it worked out.. :)
Had to take the barrel and one nut off to get the length needed for the 30s..
after that the throttle was ready to assemble and synch
image hosting above 5 mb
picture upload sites
The cable is just long enough and you have to hold the cap still and turn the carbs to install the cap. But it works and the one adjuster nut left locks it.
After rigging the throttle and synching it was on to the oil pump cable. The throw was off a bit so I had to space the barrel of the cable out of the hole in the side.cover with a flat washer and it rigged out perfect.
image hosting no registration
