Sealing the Thermostat housing
kampinguru
#1 Post by kampinguru » Mon Apr 10, 2017 9:15 am
Good morning
The parts fiche shows no gasket between the cylinder head and the thermostat housing. Mine is leaking when I filled it with antifreeze. The manual does not show using any kind of sealant on the connection but I do not see how two pieces of metal will seal themselves. Am I missing something here? Should I be using permtex to seal the surfaces? Thanks
tacky1
Re: Sealing the Thermostat housing
#2 Post by tacky1 » Mon Apr 10, 2017 10:40 am
The seal is a rubber gasket that surrounds the thermostat, The thermostst fits into the seal and that gets compressed when you tighten it all up.
This is the complete stat with seal http://www.ebay.com/itm/Yamaha-RZ500-Ma ... bh&vxp=mtr" onclick="window.open(this.href);return false;
justind97
#3 Post by justind97 » Mon Apr 10, 2017 11:11 am
There's someone on here that had taken the housing off, and machined a groove for an o-ring.
kampinguru
#4 Post by kampinguru » Mon Apr 10, 2017 1:43 pm
justind97 wrote:There's someone on here that had taken the housing off, and machined a groove for an o-ring.
That would be the perfect solution. If you want to run without a stat, something needs to provide the seal.
Bare
#5 Post by Bare » Wed Apr 19, 2017 7:25 pm
You should be using the thermostat and it's rubber seal.
Which (the rubber ring) is the same part as that found on a Saab 900 or 9000.
Likely others as well. But that's what I have on hand.
Beyond that, Goop the hell out of the flange .. and hope
kampinguru
#6 Post by kampinguru » Mon Apr 24, 2017 8:59 am
Thanks guys. I broke down and bought the thermostat. All tight now.
