Has anyone use one of these and find its worth the investment?
http://vintagesmoke.com/product/digital ... ing-gauge/" onclick="window.open(this.href);return false;
Timing gauge
Timing gauge
- Timing-gauge-bare-600x600.jpg (99.27 KiB) Viewed 3414 times
Re: Timing gauge
I have a dial gauge version off ebay, was a lot cheaper :/
Re: Timing gauge
I have had the same dial indicator for over 40 years. It always works and the battery is never dead.
Re: Timing gauge
Why dont we have a 'like button'...? I so want to click that on Walt's post, too funny.
Re: Timing gauge
Any other brand recommended?
Re: Timing gauge
Erm Use a degree wheel (print one out) and cobble up a piston stop from sparkplug.
Dial gauges of whatever design get into piston dwell issues and this variance can be significant when timing setup .. is in fractions of a mm.
Degrees on a wheel are Far more reliable and replicable.
Re: Timing gauge
The zeeltronic site has one you can print out for free.
Re: Timing gauge
I prefer this one:
Awesome tool. No batteries, no sensitive mechanic. Always keep it in my toolbox.
Loosen the lock-screw for the pin and shove in the pin.
Set the gauge mark to 0 and slightly tighten the lock-screw.
Slowly turn the engine over will push out the pin.
Tighten the lock-screw and turn in the gauge screw to the desired ignition advance (i.e, 2 mm BTDC for 20 deg BTDC for stock RDs).
Then slowly turn the engine until the piston is locked by the pin - voila, the crank is in the desired position and you can create some mark on the flywheel/housing
Remove the device and screw in the plug.
Strobe this position on the running engine.
The trick bit is the 1mm thread for the inner part. It act's like a micrometer (i.e. each of the 10 outside marks equals 0.1 mm)
The downside: Can't tell where to buy that nowadays. As it has no display, today's kids wouldn't buy it ?
