Clutch stocked/hanging Help
Mcqeen
#1 Post by Mcqeen » Thu Feb 08, 2018 6:19 pm
Hi forum :smt041
Messing with left clip-on, removed the clutchlever and wire...
Remounting wire and lever... and the clucth is hanging and there is no tension on the wire!!!... :smt010
What/how can i get the clutch released again?? :smt017
Regards Stig
Re: Clutch stocked/hanging Help
#2 Post by hondaror » Thu Feb 08, 2018 8:35 pm
Hi Stig, check the cable (wire) at the clutch arm end. (Under the carbs). It will often come off there when you remove the lever.
Mcqeen
#3 Post by Mcqeen » Thu Feb 08, 2018 9:39 pm
The cable and lever is fine...
It is like the clutch has been "over pulled" when i was dismounting the cable and the clutch has locked and wont release itself again...
The clucth arm didn´t return after tension.
Hope it makes sense... Engwish not first lagunes :smt002
#4 Post by hondaror » Fri Feb 09, 2018 1:29 am
I'd drop the oil and pull the case. You might have broken plates.
Mcqeen
#5 Post by Mcqeen » Sun Feb 11, 2018 10:44 pm
Hmm... Ok, i will report back what happend
Mcqeen
#6 Post by Mcqeen » Sat Sep 08, 2018 8:14 am
Completly forgot about returning with the clutch issue and solution :smt015
When removing the clip on´s, i heard a little noise... like when your dropping a 5mm nut to the floor, you didn´t see were it landed and start to wonder if you heard rigth, because the sound has nothing to do with the work your doing... Yes?? :smt048
I grabbed my Haynes manual, read about the clucth adjustment, dismantling and removing the clutch, got my tool and on with it... :smt038
I ended up with doing it five times :smt042
Step by step, before deciding that there is nothing wrong with the clutch... i have done it rigth according to the book :smt017
Thinking very hard about it :smt017 I remembered the litle noise i had heard and whent backwards to where it all startet and looking at the lever and cableadjuster...cable beeing ca. 1cm to long.... :smt018
Was that the sound???... and extra customized cable adjuster, that i made years ago do to the long cable...FUUUUUUUUUCK ME!!!! :smt021 :smt021
No further questions your Honor :smt086
The clutch is now in a god working order :smt002 :smt023
Moderator
Moderator
#7 Post by silverstrom » Sat Sep 08, 2018 5:25 pm
Lol...funny how memory fails us as times.
#8 Post by hondaror » Sun Sep 09, 2018 1:10 pm
Glad you got it all worked out.
