Hey Guys,
I have a 85 RZ350 that was running in premix when I bought it and have ran it that way since. The Oil Pump is still in the side, however I would like to get it connected back up again. I'll need to get hoses, but is there a safe way to test this pump? Just leave the hoses off the carbs and see if it starts pumping the oil through? I know there will be some fine tuning to do afterwards with the pump but would like to hook that thing back up.
Any brand that you guys recommend (I know loaded question) on injector oil? I usually use Belray oils and noticed that have a injector oil as well as a premix oil.
Thanks in advance,
Jeff
1985 RZ350 - Back to Oil Injector Pump advice
Re: 1985 RZ350 - Back to Oil Injector Pump advice
For absolute peace of mind send it to Arrow, A member on here, in the UK
It will come back newer than new and in perfect working order
Thanks Howard.
If it's been running for a while with the pump on and no oil connected to it the pump will be scrap.
