ZeelTronic Ignition
savethe2strokes
ZeelTronic Ignition
#1 Post by savethe2strokes » Mon Mar 13, 2017 9:41 pm
I would like to run close to stock timing after my recent motor detonation. Does anyone have a stock ignition tune for the ZeelTronic unit?
85 RZ350-Messed up wiring
JonW
Re: ZeelTronic Ignition
#2 Post by JonW » Mon Mar 13, 2017 11:53 pm
AFAIK it comes with the 31K in it already as a standard map.
MK
#3 Post by MK » Wed Mar 15, 2017 5:10 pm
First I'd ensure that the static angle is set right.
Otherwise any map will be shifted by the amount of error on the static angle.
If you need the stock curve GIYF:
http://www.bdkraceeng.com/Images/350ypvs.gif" onclick="window.open(this.href);return false;
savethe2strokes
#4 Post by savethe2strokes » Sun Mar 19, 2017 10:24 am
What is the best way to tune it: computer or handheld?
MK
#5 Post by MK » Sun Mar 19, 2017 11:00 am
Both.
Handheld is good on the road, on track or at the dyno.
PC is good at home and you can save all settings at once in a file. These files can be exchanged with others to debug things or save them entering all the numbers.
savethe2strokes
#6 Post by savethe2strokes » Sat Mar 25, 2017 2:11 pm
These look to be about Stock for the bike. Can you have a switch wired in to run different mappings? How would you know what map is what?
Ignition Setup.png (27.58 KiB) Viewed 3065 times
PV Mapping.png (28.23 KiB) Viewed 3065 times
