If you have a VJ22B RGV CDI laying around and want a programmable ignition you should get a Zeeltronic VCDI-04 and wire it like this:
Or if you want the even cheaper version: Skip the VCDI-04 and wire white-red from stator to brown-white and red-white on the CDI.
This will fire directly when the pick-up approaches the lobe and you have a "static" curve.
Note that in this case you need to rotate the stator plate to adjust some 20 deg at idle (on the LC's that easier).
DC-CDI for cheapskates
