yamaha 350 lc
neilstar
yamaha 350 lc
#1 Post by neilstar » Sun Sep 18, 2016 4:44 am
hello, hopefully someone can help me solve these electrical issues, thank you in advance
1981 Yamaha rd350lc
new battery fully charged, doesn't seem to be charging whilst bike running,
turn ignition on and nothing, use to light up red and green dash light
bike will start and run no probs, once started green and red dashlight on
headlight flickers all over the place, while revving,
indicators work sometimes, mainly with high beam on,
indicators work if I hold front brake on
any help would be much appreciated
cheers Neil
two-stroke-brit
Re: yamaha 350 lc
#2 Post by two-stroke-brit » Sun Sep 18, 2016 7:05 pm
sounds like you have a few shorts in the loom or connections to me.
i hate electrical probs mainly because i dont understand it enough.
mark
Frank t
Re: yamaha 350 lc
#3 Post by Frank t » Mon Sep 19, 2016 8:06 pm
I would check the fuze box. The stock fuze clips lose tension or break causing problems like you describe. My bike had some of the same problems all solved when I replaced the fuze box with blade fuzes.
Frank Tarpley
1988 TDR250, 1974 GT380, 1968 Cobra, 1984/1987 RZ350, 1983 BMW R80st
Zedixe13
Re: yamaha 350 lc
#4 Post by Zedixe13 » Mon Sep 19, 2016 9:04 pm
Also main harness grounds to the frame .
Re: yamaha 350 lc
#5 Post by JonW » Mon Sep 19, 2016 9:41 pm
go through and waggle[1] every connection, especially inside the headlight.
1 - Its like a wiggle, only more manly. :D
neilstar
Re: yamaha 350 lc
#6 Post by neilstar » Thu Sep 22, 2016 4:06 am
thanks all, will try again tonight,
have no power when turn on ignition, but bike starts and runs fine,
done lots of wiggling,
only earth I know of is the one directly behind ignition coil?
should there be any others anywhere
what is the spare loose black connection next to the indicator flasher unit, next to battery
unsure what that is for,
thanks again Neil
two-stroke-brit
Re: yamaha 350 lc
#7 Post by two-stroke-brit » Thu Sep 22, 2016 9:57 am
neilstar wrote:thanks all, will try again tonight,
thanks again Neil
i think that's an earth too .
when i look at the schematic wiring diagram all the blacks are earths.
but i know shit about sparky stuff [smilie=yikes.gif]
Bare
Re: yamaha 350 lc
#8 Post by Bare » Fri Sep 23, 2016 3:14 pm
Without knowledge of how much you like your Bike Or how much work you are willing to put into it?
Ideal would be to 'Remove' the entire wiring harness from the bike and lay it out on a sheet of Plywood.
Anchoring all the connectors so they stay put.
Then strip All the tape wrap.. exposing All the contained wires.
Good chance you will find Burnt Black wires . Yama had (has?) a years long Bad habit of Economising on ground circuits.
Very often such a strip down shows the effects. . Fix those and check each wire for continuity..
Yess.. All a bit of a Pain. But it eliminates further wiring problems.
Also add a decent sized Black wire link direct from Battery Negative to the Frame.
