Stator
lokie21
Stator
#1 Post by lokie21 » Tue Oct 04, 2016 8:43 pm
Hello, I`m having trouble with my stator and I was wanting some sources for a new one or possibly getting old one rebuilt. I did stumble upon this website http://www.regulatorrectifier.com/catal ... 350-Stator" onclick="window.open(this.href);return false; that claims to have a stator that fits 83 to 90 rz`s. Is this possible? and has anyone bought one from this site. your help would be very much appreciated. Thank you Dave
lokie21
Re: Stator
#2 Post by lokie21 » Wed Oct 05, 2016 2:26 pm
Hello is this thing on!!!
Re: Stator
#3 Post by RuZty » Wed Oct 05, 2016 8:51 pm
lokie21 wrote:Hello is this thing on!!!
Considering that half of the time between your posts was middle of the night I think your expectations are a bit high. You did get 49 views though, would it make you feel better if 30 of those posted up 'No' as an answer to your question?
I have always found decent used ones and have several spares kicking around for future use. Beware when buying used or aftermarket that there are variations of stator/rotor/CDI and not all play well together and some require minor mods to work. Searching on here will help clarify things.
Re: Stator
#4 Post by MK » Thu Oct 06, 2016 6:43 am
First it would help to post a working link.
I get an error message that the page cannot be displayed.
tacky1
Re: Stator
#5 Post by tacky1 » Thu Oct 06, 2016 10:33 am
MK wrote:First it would help to post a working link.
Works fine for me.. http://www.regulatorrectifier.com/catal ... 350-Stator" onclick="window.open(this.href);return false;
Re: Stator
#6 Post by MK » Thu Oct 06, 2016 1:20 pm
What I see:
Why Am I Seeing This?
A 403 Forbidden error means that you do not have permission to view the requested file or resource. While sometimes the website owner does this intentionally, other times it is due to misconfigured permissions or an improper .htaccess file.
Anyway. No matter what the manufacturer promises, the rotor, source coils and stock CDI build a tuned system that basically work together if you have the right combination.
There's a big chance that the new stator changes that to the worse side, i.e the stock CDI does spark or does not rev too high.
That's why I usually recommend a DC-CDI coz they're not affected by this rotor/stator/CDI combo issue. They just need a stable 12V supply and the 12V coils do work in all aftermarket stators in combination with all rotors.
If your old stator just has faulty source coils and the 12V part still works, you can use that one with a DC CDI instead of wasting money on a new stator.
lokie21
Re: Stator
#7 Post by lokie21 » Thu Oct 06, 2016 2:41 pm
Thank You Martin, I don`t know why the link doesn't work for you. it works fine for me. Maybe it`s because USA gave up control of the Interwebs.
hablair
Re: Stator
#8 Post by hablair » Fri Oct 07, 2016 12:43 am
Stupid question Martin
The link showing the stator, is that the one you are recommending to use? Or is there another you have in mind?
Any one had any results, good or bad, with this manufacturer
I have tow Rz's and 83 and an 85 that I'm sure will require a new one in the not too distant future
Howard
Re: Stator
#9 Post by MK » Fri Oct 07, 2016 12:21 pm
As I wrote: My experience with ANY aftermarket stators is that the stock CDI often doesn't like them.
So if you have trouble and hope to finally cure it with a new aftermarket stator, you may get disappointed.
The good news: Try the DC CDI first, as it eliminates any old CDI trouble plus source coil issues at once AND adds some 5 hp for 200-250 bucks.
Only requirement: Pick up (white/red white/green, some 130 -200 Ohm) and the 12V charging coils (three white cables, 0.6 Ohm each pair) must work.
hablair
Re: Stator
#10 Post by hablair » Fri Oct 07, 2016 10:23 pm
Ok sorry got a bit confused there
Stator & CDI two different beasts LOL
so you are referring to a zeel or ignitech then? and then you can use the aftermarket stator? yes/no
Howard
Re: Stator
#11 Post by MK » Sat Oct 08, 2016 6:44 am
Yes, exactly.
With a Zeeltronic take care of ordering a PDCI and not a PCDI. The Ignitechs are all DC type.
And I need to add that if your stock stator has a working 12V supply, you don't even need a new stator.
Measure white against white and if each of the 3 pairs have 0.6 Ohm it's ok.
