coil test
Re: coil test
Ok...I took a multimeter and stuck the probes into the pigtail coming off the coil. I had the multimeter set at 200. I got a reading of 1.5. My manual says 0.33 +/-10%. I then took one of the probes out of the pigtail and stuck it into one of the spark plug wires. The multimeter was set at 20k. I got no reading at all. Anyone know if I did this right? The readings I got say my coil is no good.....is that correct? Thank you.
