85 Canadian Electronic Tach Wiring
DRC
#1 Post by DRC » Sun Jul 02, 2017 2:09 pm
I have an Canadian 85 frame and gauge cluster that I'm going to use on my Athena build (I thought it was an 84 until i pulled it out of the basement)
The motor and wiring harness will be from a Canadian 83.
I would like to use the Electronic Tach in the 85 gauge cluster and need to splice it into the 83 harness. From what I can remember...
- The Grey wire from the tach was spliced into the orange wire going to the coil - I believe the 86 and later may have taken the signal from the CDI
- The Black wire was the ground
- The Brown wire was the power that also supplied power to the temperature gauge.
Is someone able to confirm this? Do does anyone have a clear scan of the 85 wiring diagram.
Thanks in Advance...
Re: 85 Canadian Electronic Tach Wiring
#2 Post by MK » Sun Jul 02, 2017 3:20 pm
In all years the electronic tachs are not using the orange wire in the CDI (which goes to HT coil primary). They all connect to the black-yellow between CDI and PV controller.
So the right scheme is
- black => ground
- brown => + 12V
- grey => black-yellow
Zedixe13
#3 Post by Zedixe13 » Sun Jul 02, 2017 7:21 pm
