Zeeltronic Igntion and PV settings
Does anyone have a stock setup file? It looks like my PV settings may be off from stock and I would like to run stock until I get my jetting sorted out. If anyone has this already built it would be greatly appreciated.
85 RZ350-Messed up wiring
Re: Zeeltronic Igntion and PV settings
zeeltronic- Setting up power valves 2 smoked google this
Curve 1 - Curve 2
Point 1 2k 17.0 - 2k 17.0
Point 2 3.5k 27.0 - 4.5k 29.0
Point 3 9k 17.0 - 6k 29.0
Point 4 9.9k 9.0 - 9k 20.0
Point 5 11k 9.0 - 12.5k 4.5
Static angle 34 degree
Compensation 30us
PV parameters
Deviation 5%
Closed position 240
Open position 512
PPR 2
Tigger mode + & -
There are 5 PV curves programmed
Curve 1, 5.5k 0%, 9.5k 100%
Curve 2, 6k 0%, 8,6k 100%
Curve 3, 5.5k 0%, 6.5k 25%, 7.5k 40%, 8.6k 100%
Curve 4, 5k 0%, 5.5k 10%, 6.5k 40%, 7.5k 80%, 8.3k 100%
Curve 5, 6k 0%, 8.1k 100%
These are the parameter values i recorded before I made any changes.
Compensation 30us
PV parameters
Deviation 5%
Closed position 240
Open position 512
PPR 2
Tigger mode + & -
1973 RD350
2014 Suzuki DT1000
1979 RD400F Daytona Special
2014 Suzuki DT1000
By the way stock curve from Yamaha was 2k-16, 3.5k-27, 9k-16, 9.9k-9,
1973 RD350
2014 Suzuki DT1000
2014 Suzuki DT1000
Those Powervalve settings are stock? It is closed at 5500 and wide open at 9500 RPM?
Looks like my ignition is setup just like stock.
