RD350LCII Auto battery charger
ARRuss-81
#1 Post by ARRuss-81 » Fri Sep 29, 2017 11:26 am
Hello everyone,
I'm new here in this fantastic community. I've Owned a Yamaha RZ350-RD350LCII since December 2015 so thought it was about time to join the community.
I might need to approach some help for the auto battery charger in my (RD350LCII) bike.
As the exposition appears, This auto battery charger circuit can be utilized to charge 12V and 6V batteries. On the off chance that it is utilized a transformer that can convey 4A to 5A at a voltage in the vicinity of 12.6V and 16V then we can dispose of the switch for 6V or 12V batteries. The schematic is given beneath.
It similarly gave some helpful tip about the auto battery.
The auto battery charging current is consequently constrained to 4.2A. On the off chance that there is a 600mV voltage on R1 (4A through it), at that point, the T1 transistor begins to direct. Inordinate charging current is stayed away from in light of the fact that the present estimation of T3's base is constrained. The distinction between connected load current (at T4's authority) and genuine voltage of the battery are adjusted through T4's gatherer producer intersection. According to the datasheet of 2N3055AG - https://www.icrfq.com/part/1926205-2N3055AG.html" onclick="window.open(this.href);return false;
The power contribution of 2N3055AG is the result of load current and voltage distinction as of now said. While charging 6V auto battery this power achieves a greatest of 40W. The rectifier diodes must have the capacity to convey 4A at 40V. T4 2N3055 must be mounted on a decent heatsink keeping in mind the end goal to scatter the warmth.
I can't comprehend what byx21-40 is?
1) Is it like a diode rectifier ??
2) And what is 21-40 implies like between 21-40 or simply it's datasheet code (since I scarcely discovered it on google)
3) And if it's being sold similarly as it is and considers the possibility that I didn't discover it in the market.
Sorry to everyone asking for too much question.
gpaddict
Re: RD350LCII Auto battery charger
#2 Post by gpaddict » Sat Sep 30, 2017 9:19 am
uuuummmmm, what? Sorry, too complicated for me to follow.
#3 Post by RuZty » Sat Sep 30, 2017 8:46 pm
That is a whole load of Google Translate of something about alternators Why don't you tell us where you are from and maybe someone can offer support in your own language. Welcome to the forum!
ARRuss-81
#4 Post by ARRuss-81 » Sun Oct 01, 2017 7:39 am
Hello Ruzty, thanks for the warm welcome! Sorry for my poor English.
hablair
#5 Post by hablair » Sun Oct 01, 2017 9:47 am
I'm no electronics engineer
I've just looked at your link
Its not an alternator, it is a transistor to be used as a step motor or for audio purposes
I doubt you could use it to charge batteries on a bike, the stator and fly wheel produce voltages of about 240V, the regulator/rectifier converts this down to 13.6V to allow them to charge the battery, run the lights etc
Something more simpler would be the answer
