anyone know what the swg of the main harness is on the early RZs.
thanks mark
S W G of early rzs
- two-stroke-brit
S W G of early rzs
Re: S W G of early rzs
Probably 'Not big enough at least in relation to the alternator to reg wires, but irrelevant as connector took one for the team.
Just wire it all in 18awg and you'll never have problems again. Except maybe routing. Or turning the handlebars.
- two-stroke-brit
That cheered my Wednesday up(F5) wrote:Probably 'Not big enough at least in relation to the alternator to reg wires, but irrelevant as connector took one for the team.
Sadly I recently bought some to redo the RZ Ignitech ignition. But I can't remember the gauge I used. Modern automotive thin wall can cope with more current but I'd not go undersized.
I used this sort of stuff from these chaps but you'll find something more local.
http://www.vehicle-wiring-products.eu/s ... wall-cable
Checks garage. . .
Hmm, nope no receipt . Measures about 1.4 odd mm so probably the 28 strand. I also bought the size up for power and coil, but that was a swine to get into the tiny pins of the Ignitech and way overkill.
Checks garage. . .
