TZ style seat on a YPVS 31K
Has anyone done this?
I am looking for some pics to see how it would look if anyone has any?
Re: TZ style seat on a YPVS 31K
I would love to do it with a period seat. I believe the frame rails are too wide for the TZ seat, so you'd have to modify those rails, cut, strip and weld and then paint. +++.
You'd be better off making a plug and making your own knock off. Check out AirTech, as they have a decent selection of bodywork and could verify what will work.
Well I thought someone would have done this at some point?
Have a look at this one:
http://www.corujoxx.com/MIWEB3/replicas.htm" onclick="window.open(this.href);return false;
That's what I have been looking for. I am surprised you don't see more bikes like this
Every time I see a pic of a TZ 750 i wonder if you could do something similar?
- RZResurection
I want to do the TZ250S tail at some point. I went with a Honda RS250 instead. It was wider and was to easy to fit.
Jeff
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Milled Head (0.020")
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
Well I have just ordered one of thos TZ seats. i am going to have to cut it an re-model to fit the rails. I haven't really used glass fibre before, so should be fun
Show us pics when you get it. Would love to see that.
Well this is where i'm at. i have had it all sprayed etc, but when I fit the bodywork and seat, I just don't like how it looks because of this the bike has sat unloved for about a year. not sure weather to cut the bracket of the bottom of the tank, or put a strip across it yet?
Should probably have decided to make these alterations, before I got this far
- RZResurection
If you don't intend to use the stock side panels, then remove the tab. I removed mine. It's useless with any other bodywork.
Jeff
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
But then a valuable tank becomes worth much less!RZResurection wrote:If you don't intend to use the stock side panels, then remove the tab. I removed mine. It's useless with any other bodywork.
85 RZ350
88 YSR50
82 RD350LC (Current project)
97 Honda RS125 (race bike #1)
89 RGV250 VJ21
85 RG500
85 RZ350 Hybrid
86 GSXR750
88 YSR50
89 RGV250 VJ21
85 RG500
85 RZ350 Hybrid
86 GSXR750
- RZResurection
True. But, it's been painted - less value now. Would he ever sell the tank separate from the bike - maybe. If that was a spare tank, I'd say keep the tab. If that is the tank that will be used with the bike - hack it off if it serves no purpose. Unless he wants to be able to go back to a stock bike at some point, it's not needed.
Jeff
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
Well i have done a quick mockup to see how the seat will look. it's a bit late now as i've cut the sub frame
I have a 2" strip through the center of the seat to re-glassfibre and it needs to be re-modeled where it meets the tank
Hi,
Interesting thread. I am doing the same with an F2 frame and some parts left over from another project. I wanted a minimal seat that didn't look too out of place on the F2 - not easy given the shape of the F2 tank. I got this seat of ebay;
I had to cut the frame tubes at the back to make it fit, and had seat supports welded in to support it properly. Battery will live in the tail section. I alo had a flat steel plate welded in as a rear mudguard;
Dusty
Dusty
Cool thread. I'm currently building one and did a bunch of photoshop mock-ups, but it was hard to find a seat that looks good with the RZ tank. The TZ250S seat definitely looked the best to me, but I feel it would need to be shortened to look right. I ended up using a TZ250G tank and TZ250H seat and made a new subframe.
