TZ style seat on a YPVS 31K
- aaronmvrider
Re: TZ style seat on a YPVS 31K
hope you fellas are short... going to be sitting pretty low.... and if you add rearsets you will be in a cramped position
1 x 4mm stroker rz 375cc 1983
1 x rz 500
1 x mv agusta 1000
1 x rz 500
1 x mv agusta 1000
Now that is just killer! Nice work.uncledirty wrote:Cool thread. I'm currently building one and did a bunch of photoshop mock-ups, but it was hard to find a seat that looks good with the RZ tank. The TZ250S seat definitely looked the best to me, but I feel it would need to be shortened to look right. I ended up using a TZ250G tank and TZ250H seat and made a new subframe.
- aaronmvrider
how do you take engine out... enough clearance with barrels on
1 x rz 500
1 x mv agusta 1000
1 x rz 500
1 x mv agusta 1000
uncledirty wrote:
I'm digging that Firebird Formula. Yours?
Thank you kindly!hondaror wrote:Now that is just killer! Nice work.uncledirty wrote:Cool thread. I'm currently building one and did a bunch of photoshop mock-ups, but it was hard to find a seat that looks good with the RZ tank. The TZ250S seat definitely looked the best to me, but I feel it would need to be shortened to look right. I ended up using a TZ250G tank and TZ250H seat and made a new subframe.
Top end goes on after the cases are in and visa versa.aaronmvrider wrote:how do you take engine out... enough clearance with barrels on
Yes, it's a `71 matching numbers car with a 400ci and the some-what rare sandalwood interior.silverstrom wrote:uncledirty wrote:
I'm very jealous. The Firebirds are on my favourites list, right after a few Mopars. I've owned a couple over the years. Often think about bailing on bikes and going back to 4 wheel classics.uncledirty wrote:
I really like the look of thathondaror wrote:Now that is just killer! Nice work.uncledirty wrote:Cool thread. I'm currently building one and did a bunch of photoshop mock-ups, but it was hard to find a seat that looks good with the RZ tank. The TZ250S seat definitely looked the best to me, but I feel it would need to be shortened to look right. I ended up using a TZ250G tank and TZ250H seat and made a new subframe.
- RZResurection
I like it too. The tank and the seat look like they belong together. If you put on a period fairing - it will be an awesome looking machine.
Jeff
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Milled Head (0.020")
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
Thanks guys! It's getting an OW31 fairing and done up with OW31 paintwork. Hoping to have it done by next spring.
uncledirty, that's FZ600 wheels and swinger? Which year?
Swinger is `86 FZ600 with `89 GSXR750 rear wheel, R6 shock. It's a common mod for the RZ, and plenty of threads on the conversion can be found on this site.hondaror wrote:uncledirty, that's FZ600 wheels and swinger? Which year?
Thank you, front end?
The front end is `91 Gixxer 750. I had this front end laying around and was super easy to fit to the frame.hondaror wrote:Thank you, front end?
I'm most likely going to go with an R1 front end as the old gixxer stuff is heavy and have long forks.
The tank took some work to get it to fit. I had to cut the bottom out of the front half as the TZ tank have a sump that extends below the frame rails. It allowed me to recess the bottom to keep the electronics in the stock location with room to mount a smaller battery so all the electrics will be hidden under the tank. I also had to relocate the petcock to the rear of the tank.
this my friends rd421cc
- 1472929_602425239793682_1860688034_n.jpg (86.7 KiB) Viewed 4593 times
is there rd421cc kit with 2006 r1
