Windscreen fasteners for RZ350?
dauer
#1 Post by dauer » Thu Aug 14, 2014 8:30 pm
As the title states I'm trying to source OEM style windscreen fasteners for my '84 RZ350 KR, I discovered they are no longer available from Yamaha. I searched various sites but came up empty until I found a kit from economy cycle, unfortunately they are 5mm not 4mm. Any info or leads would be appreciated. Thanks
Re: Windscreen fasteners for RZ350?
#2 Post by RuZty » Thu Aug 14, 2014 8:56 pm
5mm drill?
Moderator
Moderator
#3 Post by silverstrom » Thu Aug 14, 2014 9:36 pm
Ron Ayers still shows them as available. http://www.ronayers.com/FAIRING-COWLING-C484596.aspx" onclick="window.open(this.href);return false;
The 86-90 hardware is still available from Yamaha. Those are plastic screws. Are the 84 screws plastic?
aaronmvrider
#4 Post by aaronmvrider » Fri Aug 15, 2014 3:18 am
yes plastic 84
1 x 4mm stroker rz 375cc 1983
1 x rz 500
1 x mv agusta 1000
dauer
#5 Post by dauer » Fri Aug 15, 2014 7:25 pm
silverstrom wrote:Ron Ayers still shows them as available. http://www.ronayers.com/FAIRING-COWLING-C484596.aspx" onclick="window.open(this.href);return false;
This is very helpful, thank you.
AK Addict
#6 Post by AK Addict » Sat Aug 16, 2014 10:30 am
Hopefully Ron Ayers does have them but I've found they don't keep there fiche updated, order parts listed as available only to get an email later that they can't get them. Partzilla does a better job of keeping there fiche updated. I've read that you can tell by the part number the size of the screw but I'm unsure what number in the part number to use.
90157-04062 84-85 USA model
90150-05020 89 Canadian
I'm guessing the 90157-04062 is 4mm and the 90150-05020 is 5mm?
Is that correct?
nokturnal
#7 Post by nokturnal » Sun Aug 17, 2014 8:47 am
I have a set stashed. they are metal. olivish
:smt017
dauer
#8 Post by dauer » Sun Aug 17, 2014 11:54 am
My screws are 4mm, the ones I got from economy cycle are 5mm. I was unaware of this until they arrived ay my door. I'm going to send out a few emails this week and see what I can find out.
dauer
#9 Post by dauer » Mon Sep 01, 2014 11:09 am
Thought I might update my findings. My search for OEM screws proved fruitless. However I did discover that the 5mm screws from economy cycle fit with no drilling. May have been wise to check that before starting a thread on it... None the less the 5mm are a nice fit and also beefier than the tiny OEM screws that tend to either vibrate out or snap.
concours
#10 Post by concours » Sun Aug 21, 2016 4:42 pm
I found the correct M4 x .7 x 12 black nylon phillips pan heads here: http://www.mcmaster.com/#nylon-screws/=13tpltt" onclick="window.open(this.href);return false; P/N 92492A222
They also have large flat washers that are a perfect fit here: http://www.mcmaster.com/#standard-washers/=13tplc0" onclick="window.open(this.href);return false; P/N 90377A137
And the nuts.... http://www.mcmaster.com/#hex-nuts/=13tpkbf" onclick="window.open(this.href);return false; P/N 98676A200
I was all set to buy a bunch, sell kits to those that needed them, but then I found my missing one when cleaning the bike lift. I hope it helps some others.
WFO for 45 years
1973 Yamaha TX750
1975 Yamaha DT400
1974 Norton Commando 850
Triumph Tiger 1050
Triumph Rocket III
