Anyone know where I could find a replacement helmet lock and barrell for an '84 U.S. model? I need the whole set up, everything is shredded I believe from a wipe out.
Certainly not #1 on my list of things needing attention on the bike, but it's always RIGHT THERE! where i'm looking.
Helmet lock?
Re: Helmet lock?
Just keep on the lookout for one. The original lock on mine had the keyhole all buggered up and, not a priority but it was the first thing I saw. Found one on ebay I think. Good luck.
Re: Helmet lock?
If you don't want to end up with 2 keys , look for one with the same first digit on your main key ( A B C D E F ) . You will be able to swap your damaged lock pins in your replacement lock and keep the same key , very easy to do . FJ600 84-85 had the same lock , also RD350 LC , the lever is different but interchangeable .
