solo seat leads?
- Evans Ward
Re: solo seat leads?
Just like Brian did, I found a cracked and damaged one on ebay and bought it cheap. Had a body shop fix it before getting it painted and decaled. The OEM unit will have the molded tabs inside the unit for the large O rings to grab and attach to. Not sure if the repop ones have that or not?
- Contact:
FWIW I have a cruze image and its an exactct replica done in plastic not fiberglass. came with back pad, mounting brackets and the mole around the taillight. It also has the bumps for O rings. Haven't painted it but there is no seam.
Hey?!?! Mine wasn't cracked or damaged??? Just primered and had a black guide coat sprayed on it! I thought it was a steal!Evans Ward wrote:Just like Brian did, I found a cracked and damaged one on ebay and bought it cheap.
1984 RZ350L
Many thanks to www.WilsonPerformance.net !!!
- Evans Ward
Ooops! Should have said used one like Brian's. Used (and/or damaged) can be a viable option for those looking for an OEM piece.BrianT wrote:Hey?!?! Mine wasn't cracked or damaged??? Just primered and had a black guide coat sprayed on it! I thought it was a steal!Evans Ward wrote:Just like Brian did, I found a cracked and damaged one on ebay and bought it cheap.
G'day race fans. IMO! a SOLO seat cowl should be in the top 3 reproduction parts available for an Rz350. 4-5 months ago an original unused genuine cowl sold for $500 and something dollars in Australia through e-bay and there where many bidders. At the moment i would like to buy 2 reproductions if i was able to source them. I'd happily pay $200 ish for just fiberglass cowl, to $300+ for Abs plastic including mounting hardware and the like. Is there a possibility for fellow forum members to organise a group production run?
In my state of Queensland Australia, it is half price annual road registration if a motorcycle is classed as a one person ride,(full price is $450), Ie solo seat and no rear foot pegs. Does anyone have a donar cowl to loan for a reprodution mould??
yamaha fanatic.
- aaronmvrider
i have a solo seat and am looking into a carbon fiber or glass reproduction... the last company i had this done with might sell the mould ??? as they are selling the business or closed down ???
1 x 4mm stroker rz 375cc 1983
1 x rz 500
1 x mv agusta 1000
1 x rz 500
1 x mv agusta 1000
Put me down for 1 or 2.
Mitsuo aka cruzinimage had the best all-in-one kit. Too bad he sold out of it. He may get some more made in the future. The other option is to get National's Fiberglass cowl/brackets and then get the pad from Mitsuo.
Of course if you want the premium package, contact RZsunlimited and expect to pay top dollar:
Complete Solo Cowl Kit with Original Paint & Graphics: Call for Price & Availability
Complete OEM Solo Cowl Kit with Graphics Requiring Paint: $799
Complete ABS Replica Solo Cowl Kit with Graphics Requiring Paint: $350
Call for Paint Service Quote
Spare Parts Available Separately
OEM Solo Cowl Body Panel (shell only) $350, ABS Replica $150
OEM Steel Bracket Set $70-90, Stainless Steel Bracket Set $59
OEM Seat Pad $350 when Available, Import Replica Seat Pad $50
Mounting Hardware & Grommet Kit $40
Rubber Trim $13
Graphic Kit Starting at $69
Rubber Trim $13
1985 RZ350N
The stainless brackets seem good value from that list...
Mark at RDDecals has the graphics cheaper than that i think... he will make sure the colours match your other graphics too.
G'day race fans. After 6 or so months of constantly looking for solo seat cowls over the internet I'm still no closer to owning 1. Still think it would be in the top 3 reproduction part wanted for a Yamaha RZ. Any new leads? How many forum members would buy a good reproduction solo seat cowl available at a reasonable price??
I'd happily pay $300 ish for a ready to mount (painted ?) cowl , including mounting hardware.
yamaha fanatic.
If someone with a mint one can loan it to 14Cheeks on here he could make repros.
Count me in. I to have been looking for a while with no luck
- mountaincycle
I pickup up a cowl from the 'Glassndude" in Ohio for around $150 USD. He makes some great quality parts..
also picked up the butt pad on Ebay.
You could try to PM the glassndude via EBay.
here's a old links..
http://www.ebay.com/itm/Nationals-Fiber" onclick="window.open(this.href);return false; ... 6b&vxp=mtr
- rz1.JPG (175.38 KiB) Viewed 4974 times
Agree with mountaincycle. Finding a solo tail is actually very easy if you do the leg work.
1985 RZ350N
I'm still very happy with my solo seat from Cruz.
http://www.rzrd500.com/phpBB3/viewtopic.php?f=4&t=9662" onclick="window.open(this.href);return false;
Hans
Hans
RZ 350 83
RD 125LC 82
Honda Xl 500 R 83
BMW F 650 1994
RD 125LC 82
Honda Xl 500 R 83
BMW F 650 1994
