My RZ350 Project in Austin, TX
Zedixe13
Re: My RZ350 Project in Austin, TX
#46 Post by Zedixe13 » Fri Jul 06, 2018 3:18 pm
ZedSledder wrote:https://www.ebay.com/itm/Yamaha-rd-350- ... tCrufsbWjg
It included free DHL shipping.
I did have to pat a whopper of a tax and duties bill. came to 150$ cdn.
UPS , DHL and other courrier service are a bunch of crooks , always ask for USPS / Canada Post when buying in US .
mixalive
#47 Post by mixalive » Wed Aug 01, 2018 9:46 pm
I painted my frame today. 76/24% blend of POR 2k Safety Red/Safety Yellow over Summit White Epoxy primer. I used a Qualspray QS-125WB Touch Up spray gun from http://homesteadfinishingproducts.com" using the 1.2mm nozzle tip. If you ever use that POR 2k, make sure you thin with 25% Xylene.
#48 Post by hondaror » Thu Aug 02, 2018 3:02 am
Saw that on the North American page. Looks great!
mixalive
#49 Post by mixalive » Wed Aug 08, 2018 10:25 pm
Here are some more images after painting.
mixalive
#50 Post by mixalive » Wed Aug 08, 2018 10:55 pm
Smoker wrote:
If he copied my frame design properly, the engine will fit in with the head installed. :smt023
The important part is to have a bend in the lower rail. I welded 2 pieces together at an angle. Can't tell from the pics, but the lower rail looks straight on this frame. I also welded the lower rails to the top of the swingarm pivot blocks on the frame for strength. The lower rails on this frame are above the blocks.
[/quote]
Earlier in the thread, I posted this: And yes, the engine fits with the head on.
mixalive wrote:Fast forward to 2015, I began researching different frame bracing configurations. I chose a system of braces based on a 90 degree lattice configuration off this site.
Now, I am a pretty good mechanic and novice fabricator. But I am not a welder. So I am fabricating all my frame mods and tacking it up for an expert tig welder. Here is an image of the bracing. I used 7/8 OD X .065 wall 1020 DOM A513 Round Steel. Because of the contour of the frame, the lower bar shown is bent inward 15 degrees at 1L-3L.
mixalive
#51 Post by mixalive » Fri Nov 09, 2018 4:59 pm
The only thing about the paint job is two of the numbers of the VIN are obscured by paint. I suppose I will need to remove the paint to better reveal the VIN. Any thoughts?
#52 Post by RuZty » Fri Nov 09, 2018 8:12 pm
The bike is already registered to you correct? I doubt you plan on selling it anytime soon after all this effort. Have you ever had anyone examine the VIN number on any vehicle? Why spoil nice paint.
mixalive
Progress Update
#53 Post by mixalive » Mon Dec 10, 2018 2:16 pm
Building the bike with a freshly painted frame. Rear Suspension
mixalive
#54 Post by mixalive » Wed Dec 19, 2018 12:43 am
Continuing on. FZR600 front end. FZ600 swingarm. FZ400 side stand. Fox Twin Clicker
Questo vecchio rz
#55 Post by Questo vecchio rz » Wed Dec 19, 2018 1:26 am
That's a really nice project you are building. Years ago, like 25+ years ago I saw 2 custom RZs at the Laguna Seca GP, same owner had modified his frames almost exactly as yours. Since then theres been a dozen or so similar..evwn a couple here.
Overall your bikes gonna look great! Keep up the awesome work my friend
mixalive
#56 Post by mixalive » Wed Dec 19, 2018 10:54 pm
mixalive
#57 Post by mixalive » Tue Jan 01, 2019 1:55 pm
Rebuilt the rear caliper, new rotor and Dot 3-4 brake fluid.
mixalive
#58 Post by mixalive » Tue Jan 01, 2019 1:57 pm
Close up of the RH Rear Sets.
mixalive
#59 Post by mixalive » Tue Jan 01, 2019 1:59 pm
Modified Battery Box.
mixalive
#60 Post by mixalive » Tue Jan 01, 2019 2:00 pm
Check out the plugs on the rear frame tubes.
