tzr/srz/rz 350-465cc
Re: tzr/srz/rz 350-443
I still haven t decidet which pipes should i buy,i was thinking between shearer and rdz but the problem is they are all for banshees so i don t know will i be abble to fit them without to much modification,what you guys reccomend?
By the time you buy off the shelf banshee pipes and have them modified to fit you may have spent as much as having a custom set made.
Another consideration is ground clearance,as displacement get bigger,pipes often do as well.
Excellent job BTW ,love to see the rear engine mount if you have a pic.
Look through the forum, Glyn is the go to guy, Kenny too. They build for your application, reasonably priced.
Done some case trenching
https://youtu.be/XpCKBreCwlo" onclick="window.open(this.href);return false;
- Questo vecchio rz
You do realize that a 10mm Cheetah motor will deliver you a guaranteed H.P figure of "at least " ( 120 h.p. and over 80 lbs if tq. )!
Drag built 10mm chettahs lay down 130-140 h.p. on Alky... It's truly F-ing INSANE.
Seriously...more than double of a stock RZ.
Seven hail Marys and few sets of rosary beads draped over your neck, and throw in a lucky rabbits foot & a lil plastic Jesus figure on your dash too...lol
I think the bhp will be around 100hp on regular 95 octan fuel I have seen many dyno graphs and they reach 110hp with 465 setup with high tuned engine but i will be more than happy with 100hp
465 machine completed
Now waiting for the shearer pipe kit to arrive
