RZ350 Ypvs Hybrid South Africa
GDA1
#1 Post by GDA1 » Thu Sep 01, 2016 4:18 pm
After finishing my CR500AF , I needed to compliment it with a Hybrid. I managed to find a RZ350 almost complete but with a few nasty surprises in the motor.
This is where I am at: new OEM solo tailpiece, VJ22 suspension front and back, R1 clocks, R6 foot pegs. Here are some images of progress and my CR500AF.
Re: RZ350 Ypvs Hybrid South Africa
#2 Post by JonW » Thu Sep 01, 2016 6:37 pm
nice project!
GDA1
#3 Post by GDA1 » Thu Sep 08, 2016 1:55 am
One of my power valves shafts were worn , I decided to turn my own bushes to make up the slack on the tolerances out of some oil lite bronze, all good now.
Questo vecchio rz
#4 Post by Questo vecchio rz » Thu Sep 08, 2016 3:28 am
Sweet open class motocrosser. The AF models are just to cool !
A year or so ago, a guy on the freeway was towing a Kawasaki KX500(AF) , I was looking at it & knew something was diffrent, but couldnt figure it out? I just slowed down admiring how trick it looked, then I finally realized what it was when I saw the "Service Honda" decals on the truck, Pretty neat toys, I'd sure like either one, but I know I'd bust myself up, beyond repair.
The RZ Hybrid is gonna look quite sharp, you can already see.
GDA1
#5 Post by GDA1 » Thu Sep 08, 2016 4:12 am
Questo vecchio rz wrote:Sweet open class motocrosser. The AF models are just to cool !
thanks Questo vecchio rz, I built the CR500AF over a period of 1.5 years, I have learnt that the finer details take all the time, there is a saying that 80% of your project takes 20% of the total time and the 20% that's left takes 80% of all the time, very true.
anyway here is the link of the CR500AF build: http://www.wilddog.za.net/forum/index.p ... c=180708.0
RZ350YPVS hybrid will follow a similar suit, for now just gathering and ensuring all is good before cosmetics are attempted.
GDA1
#6 Post by GDA1 » Sat Sep 10, 2016 11:00 am
Got my parts back from engineer, swing arm bushes hardened and aluminum parts hard anodized, VJ22 swing arm getting ready for installation.
RGVSteve
#7 Post by RGVSteve » Sat Sep 10, 2016 5:50 pm
Just wondering why you used bushings instead of bearings in the swingarm.
RGVSteve
#8 Post by RGVSteve » Sat Sep 10, 2016 5:52 pm
Just wondering why you used bushings instead of bearings in the swingarm?
#9 Post by RuZty » Sat Sep 10, 2016 9:18 pm
RGVSteve wrote:Just wondering why you used bushings instead of bearings in the swingarm?
Good to see you on here, thought you'd retired and sailed into the sunset. I hope all is well.
Maybe he made new inner races to fit the RZ pivot shaft?
GDA1
#10 Post by GDA1 » Sun Sep 11, 2016 6:19 am
Probably just my terminology, I turned two collars that fit into the stock needle bearing, in order to fit the RZ350 swing arm shaft.
yamasukiman
#11 Post by yamasukiman » Sun Sep 11, 2016 8:34 am
GDA1 where about in South Africa are you?
GDA1
#12 Post by GDA1 » Sun Sep 11, 2016 8:50 am
yamasukiman wrote:GDA1 where about in South Africa are you?
Johannesburg close to Melville [emoji106]
RGVSteve
#13 Post by RGVSteve » Sun Sep 11, 2016 9:35 am
Ruzty,
Doing well, I read on both boards I had closed up shop, I'm still here.
RGVSteve
#14 Post by RGVSteve » Sun Sep 11, 2016 9:49 am
GDA1,
You could have used the stock RZ350 bearing pivot tube as well, if you don't mind looking at an alternative I'll e-mail you some pictures of how I've done the VJ22/23 swingarms for the RZ's,
pretty much the same as you've done using the adapter plates, only real difference is in setting up the bearings for the swingarm.
GDA1
#15 Post by GDA1 » Sun Sep 11, 2016 10:04 am
RGVSteve wrote:GDA1,
Thanks Steve, I will appreciate that : gavinvdr@icloud.com [emoji106]
