tzrz350
#16
Post
by tzrz350 » Thu Oct 13, 2016 8:54 pm
South_Oz wrote:Nice job on the wiring.
Dave
Thanks!!
Another cable made, all connections from Zeeltronic to front of motorcycle (handlebar, M-Unit and Trail Tech Vapor.
Received dual horns. 300 Hz and 500 Hz, might be overkill, I may go for something lighter.
In doubt, full throttle!
1971 Kawasaki F8
1983 RZ350
2002 BMW R1150R w/sidecar
2012 Ducati Monster 1100 EVO
2014 KTM 150SX
1994 TZR350
tzrz350
#17
Post
by tzrz350 » Thu Oct 13, 2016 11:02 pm
Question, how can I add an avatar picture? Thanks for answers!
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
two-stroke-brit
#18
Post
by two-stroke-brit » Fri Oct 14, 2016 11:48 am
tzrz350 wrote:Question, how can I add an avatar picture? Thanks for answers!
go to user control panel (top left).
profile.
edit avatar.
i think it has to be smaller than 150 x 150 pixels
cheers mark
tzrz350
#19
Post
by tzrz350 » Fri Oct 14, 2016 4:38 pm
two-stroke-brit wrote:tzrz350 wrote:Question, how can I add an avatar picture? Thanks for answers!
profile.
edit avatar.
cheers mark
That is where I was, I wanted to change the avatar so I deleted the picture and wanted to select another one but the option to select a picture is not available anymore. Even using an URL doesn't seems to work (says invalid URL).
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
tzrz350
#20
Post
by tzrz350 » Sun Oct 23, 2016 5:57 pm
Looking for your opinions/solutions/advices on how to install a kickstand on the bike. Law ask for a side stand or center stand.
Thanks!
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
yamasukiman
#21
Post
by yamasukiman » Sun Oct 23, 2016 7:24 pm
Does the sidestand have to be attached to the bike or can you carry it in
your backpack?
I've seen those little triangular ones they use on MX bikes, something like that
might be a way around your problem if it doesn't have to be permanently mounted?
tzrz350
#22
Post
by tzrz350 » Sun Oct 23, 2016 8:41 pm
It has to be part of the bike and it has to fold when you push the bike forward. Not easy with that fairing...
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
#23
Post
by Smoker » Mon Oct 24, 2016 4:40 am
Fit the kickstand to the lower cowling.
Meaning, cut a section/strip of the lower cowling that will attach to the kickstand, and fold down with it. I saw it on an RZ500 and it was very nicely done.
If it was my bike, I would probably design a bracket and attach it to the frame below the shift linkage. To the bracket, I would attach a generic kickstand (sticking out enough to clear the pipe). Then, I would go and get the papers. As soon as I got home, I would take off the ridiculous kickstand and mount a custom aluminum prop and holder- polished like the frame (with the same attachment points). There would be a convenient holder on the bike for the prop, so it wouldn't slow me down.
tzrz350
#24
Post
by tzrz350 » Fri Oct 28, 2016 11:51 am
Smoker wrote:Fit the kickstand to the lower cowling. Meaning, cut a section/strip of the lower cowling that will attach to the kickstand, and fold down with it. I saw it on an RZ500 and it was very nicely done.
Like the Honda NR750, good idea, nice challenge also.
Smoker wrote:I would [...] mount a custom aluminum prop and holder. [...] There would be a convenient holder on the bike for the prop, so it wouldn't slow me down.
What do you mean by "mount a custom aluminum prop and holder"? Sorry, English is not my first language.
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
tzrz350
#26
Post
by tzrz350 » Fri Oct 28, 2016 3:04 pm
Nicely done, I'll look for his built in the RZ500 custom project section.
For the connector:
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
#27
Post
by Smoker » Fri Oct 28, 2016 3:58 pm
You got it!
Never seen a removable prop like that on any bike.
tzrz350
#28
Post
by tzrz350 » Sun Nov 20, 2016 10:22 pm
Latest addition to the project, the Antigravity battery and two Motogadget mini switches, completing the hardware components, oh, except the kickstand... this project should be ready to run for next Summer!
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
tzrz350
#29
Post
by tzrz350 » Sun Dec 04, 2016 11:37 pm
Installed the Motogadget mini switches on the left clip-on. Six momentary button for horn, hi/low beam, left and right signals and a config button. One button left...
Both wire harnesses are coming out the end of the clip-on
Not a long ride to arrive to the M-Unit. I will probably keep the full length of wires just in case I use them in a different configuration in the future
1971 Kawasaki F8
1983 RZ350
2014 KTM 150SX
1994 TZR350
driftmaster
#30
Post
by driftmaster » Mon Dec 05, 2016 2:35 pm
One of the nicest z bikes Im seen, thanks for sharing.
