RZ 350 Hooligan Build
tacky1
Re: RZ 350 Hooligan Build
#61 Post by tacky1 » Sat Sep 01, 2018 2:54 pm
Hooligan wrote:I was under the impression that hard ends on the air filters were contraindicated for a 2-stroke? I went with full foam pods on mine to eliminated the hard reflective surface at the end of the filter.
I had the same problems with K&N filters, Couldn't get the flat spot out, Switched to Uni foams and problem gone.
Yellow and Black RZ
#62 Post by Yellow and Black RZ » Tue Sep 04, 2018 10:49 am
Closed ended filters have been known to cause turbulence and can make tuning a chore.
I've always gone with foam uni filters just to eliminate the possibility.
'85 RRZ350 - Hacked.
Questo vecchio rz
#63 Post by Questo vecchio rz » Wed Sep 05, 2018 3:22 am
As mentioned previously..the K&N type, at the beginning of this post that are about 8"-10" long, have virtually zero problems, None whatsoever, on Banshees. I'd fit the longest filters you can on a RZ frame, or just use UNIs. Pretty simple & end of story?
#64 Post by hondaror » Wed Sep 05, 2018 12:08 pm
I run the short K&Ns with hard caps and pipes. No issues. I ride like I stole it. No flat spots. It hits hard and pulls.
Hooligan
#65 Post by Hooligan » Wed Sep 05, 2018 7:54 pm
Yellow and Black RZ wrote:Closed ended filters have been known to cause turbulence and can make tuning a chore.
These are what I use on my LC and they seem to work great. Mine are the 2-stage version w a red outer filter.
driftmaster
#66 Post by driftmaster » Thu Aug 22, 2019 12:33 am
driftmaster
#67 Post by driftmaster » Wed Oct 09, 2019 1:09 pm
driftmaster
#68 Post by driftmaster » Wed Oct 09, 2019 1:10 pm
driftmaster
#69 Post by driftmaster » Wed Oct 09, 2019 1:11 pm
driftmaster
#70 Post by driftmaster » Wed Oct 09, 2019 1:15 pm
