TZ/RZ 350 bitza - Cheetah 421 - R6 Fork/wheels/swingarm
Hi folks. I'm from Switzerland and here is my experience about my RD350YPVS / TZ bitza.
- RD350 modified frame
- R6 99 front end
- R6 99 swingarm
- R6 99 rims
- Cheetah 421 engine
- Jim Lomas pipes
- Dell'Orto 40 carbs
- R6 99 special shock
- TZ750 Meadspeed fairings
- Marchal front light
- TZ350 Europlast tank
- Tarozzi rearsets
- R6 99 front end
- R6 99 swingarm
- R6 99 rims
- Jim Lomas pipes
- Tarozzi rearsets
- RD420.jpg (97.74 KiB) Viewed 6867 times
- Questo vecchio rz
Re: TZ/RZ 350 bitza - Cheetah 421 - R6 Fork/wheels/swingarm
Love it ! Looks great, cool thing about the RZ is you can go 80s or 90s or a combination of both.
Like the 421, a buddy just built a economy one, using the same Lomas pipes, lays down a very respectable 76 h.p. and is completely streetable, a really fun bike.
Keep the progress coming
Thank you QV RZ i'm still working on the frame. I have to rebuilt the rear subframe to suit the new tank and I'm waiting now on Chromoly tubes sourced in Pilatus Aircrafts to sort this. I also have to modify the frame to allow the final drive chain to be perfectly strait. But here is a tip for those they want to put an R6 swingarm/rim. My solution goes through :
- 18mm offset front sprocket 520 - 17t
sourced from http://www.fastfromthepast.com
- For the rear sprocket in the way to source one with 39th in 520 but suitable for the R6 rim, the one of the Honda NC750 Integra is perfect but with holes of 10,5mm.
you car source this here : http://www.jtsprockets.com/catalogue/sprocket/JTR1303/
With this combination you have to get only 3mm on the inner area of the frame to have the correct chain clearance
Hope this helps because there is no details on the web about the chain issue after the R6 swingarm conversion.
Otherwise here is the paintscheme I choose for my bike. It's inspired by the Cagiva 500 X4 (the first GP machine of the factory of Varese, but was in fact the Suzuki 500) and also inspired by the McLaren A1M of Elvis in the movie Spinout. Frame, fork, swingarm, rims will be black and "numberplates" white separated of the champagne gold by a black line.
This color comes clear to my mind because I'm a fan of Cagiva (was formerly racing for them in supermono class in my young age), Elvis, CanAm and McLaren
Very nice build. I love your choice of tank. TZ, I assume. Which year?
I'm still not a fan of changing the bike so radically, but have to admit it looks fantastic. I don't like having to offset the sprocket, as the stresses added to the output shaft are greatly increased. Case and bearing issues. Time will tell on that one.
Keep up the great work and info. Keep posting.
Today was welding day
- 20180128_153707.jpg (169.54 KiB) Viewed 6470 times
3rd check with engine, exhaust and so
- 20180130_134425.jpg (196.68 KiB) Viewed 6403 times
That's pretty exciting. Keep posting updates!
- Questo vecchio rz
OH MAN! Love the ZX-7....It's one of the few late 80s bike I desire
Thank Questo Vecchio RZ, in Europe it's called ZXR750 Stinger, I do own this one since 10 years. Equiped with race camshafts, factory modified carbs and Yoshimura full exhaust system.....14'000 rpm
Here is the next step for the RD/TZ, the frame is naked again, and I prepare the frame modification for the lateral chain clearance. There is 3mm to gain,that mean 5 mm with plates and welding
- IMG-20180209-WA0006.jpeg (174.89 KiB) Viewed 6198 times
- IMG-20180209-WA0008 (1).jpeg (196.11 KiB) Viewed 6198 times
- IMG-20180209-WA0010.jpg (234.81 KiB) Viewed 6198 times
I think the usual solution is to use a narrower rear tire, cut down the sprocket carrier, and move the front and rear sprockets inboard.
Another less common solution is to cut and spread the frame. Still seen it many times.
I've never seen an RZ frame chopped like this, and I've seen a lot of modified RZ frames.
I like your project, but don't understand why you selected this method of modification?
Smoker, with the 180 rear tire this is the only way. But there is no issue to modify the frame this way. As long as you opt for quality steel and tig way of welding.
AC Sanctury, the renown japanese Kawasaki customizer are doing the same but reducing far more with half the section for overpowered Z900 and Z1
AC Sanctuary frame
- sanctuaryframebracing.jpg9991.JPG (129.99 KiB) Viewed 6168 times
- Questo vecchio rz
If I am interpreting your photographs correctly?
It appears as if you basiclly are creating a (deep channel) then, you will plate/fill/reinforce it ?
If so, that's pretty neat! ?. I never would have thought ,of that and it's right there in front of one to see.
I can understand keeping the tire @180 due to rim width requisite, but that is such a simple cool trick..I've had several RZ frames crack around the kickstand area, and had them repaired & welded with permanent results , A good welding job I'd think would be more than adequate there, a good welder of course...not a muffler shop...lol
Please post close up photos when you have it all final.
Hi folks, here some pictures of the frame and swingarm after welding job, sandblasting and powdercoating
Get also some titanium delicatessen
- IMG-20180319-WA0008.jpg (122.4 KiB) Viewed 5728 times
- IMG-20180319-WA0006 (1).jpg (110.71 KiB) Viewed 5728 times
- 20180310_225114.jpg (113.93 KiB) Viewed 5728 times
