TZ/RZ 350 bitza - Cheetah 421 - R6 Fork/wheels/swingarm
Re: TZ/RZ 350 bitza - Cheetah 421 - R6 Fork/wheels/swingarm
Here is the frame mod to suit chain clearance.
- 20180312_080636.jpg (71.81 KiB) Viewed 2471 times
Every day is a new day, central unit is bolted on. Waiting for the rims and forks
- Questo vecchio rz
That is coming along quite nice, good job! Thats one of, if not the cleanest builds here in many years
Thanks Questo vecchio RZ don't spare efforts to get a nice result
Rear wheel assy
- IMG_20180401_121504_911.jpg (119.23 KiB) Viewed 2334 times
Now I wait on the delivery of the old aircooled side covers to have an oldschool look for my engine.
Don't like the 80's YPVS covers, this will allow a slick finish both sides
- s-l300 (1).jpg (10.92 KiB) Viewed 2339 times
- s-l300.jpg (10.48 KiB) Viewed 2339 times
Any updates ?
I've seen Banshee builds where they've run a large offset sprocket and used an outer cover with a bearing that supports the outboard end of a modified sprocket.hondaror wrote:I don't like having to offset the sprocket, as the stresses added to the output shaft are greatly increased. Case and bearing issues.
Upper brace on the swingarm looks extremely close to the shock reservoir.
Have you been riding the bike with this setup?
I second that question it looks like its going to hit when you sit on it. Maybe we both wrongSmoker wrote:Upper brace on the swingarm looks extremely close to the shock reservoir.
I have a spare 99 frame/swing arm is anyone is trying to duplicate his work pm me
your work looks fantastic I was thinking about using my r6 swinger but gave up it was just simpler to use the stocker plus I have no wheel for that arm
Cheers keep up the good work
Hi everybody. Yes there is enough space between shock and swingarm
Yes have mounted the bearing sideplate to suit the offset sprocket
I'm now on electrical stuff
- Yellow and Black RZ
Very nice build. Please continue updates.
Appreciate it.
Appreciate it.
'85 RRZ350 - Hacked.
You are doing very nice work. I would suggest removing the spring from the shock and running the suspension through it's full travel to confirm what limits it. The shock snubber needs to limit travel, and you don't appear to have a lot.
- motoholic71
Hi how did the clurch side cover fit? I thought the aircooled cover didn't have space for the crank water pump gear. Are you going to use an eletric pump, do you have powe
r to run that?
r to run that?
