Modified RZ 350 Swingarm
DFB
#1 Post by DFB » Sun Apr 22, 2018 12:00 am
Well I went and made my own swingarm. Got tired of looking for or having to settle on that same ole one that everyone uses. I wanted a wider tire in the back is why, I Started with a 2012 ex 650 wheel and caliper. One because there's so many available, if I decided to produce more swingarms there a good source. And at 160/60/17 its wide enough.
Can anyone help me loading a picture of this.
Keep in mind I'm computer stupid.
Duane
Re: Modified RZ 350 Swingarm
#2 Post by Smoker » Sun Apr 22, 2018 12:31 am
I'm having problems with pics.
Interested in what you've done.
Is it an OEM RZ350 swingarm that you modified?
DFB
#3 Post by DFB » Mon Apr 23, 2018 2:27 am
No, I completely started from scratch and built one.
I need help loading the pictures. Why is this so hard?
Duane
#4 Post by Smoker » Mon Apr 23, 2018 2:43 am
Go here. Just post the pics. Don't even sign up.
Choose 640x480 size.
https://postimages.org/" onclick="window.open(this.href);return false;
DFB
#5 Post by DFB » Mon Apr 23, 2018 2:46 am
My custom built swing arm.
DFB
#6 Post by DFB » Mon Apr 23, 2018 2:47 am
Did that work?
DFB
#7 Post by DFB » Mon Apr 23, 2018 2:57 am
Here you go, I think this will work.
https://postimg.cc/gallery/1s53icbja/" onclick="window.open(this.href);return false;
#8 Post by Smoker » Mon Apr 23, 2018 3:50 am
Yep, pics are working.
Looks interesting.
Do you have pics of the swingarm off the bike? Details are not very clear in those pics.
Aluminum or steel? OEM or other parts in the pivot tube?
DFB
#9 Post by DFB » Mon Apr 23, 2018 10:16 am
https://postimg.cc/gallery/2k65lqag6/" onclick="window.open(this.href);return false;
I used 4130 Chromolly and all is new steel. The only this i used off the old swingarm was the bearings and dust covers.
DFB
#10 Post by DFB » Mon Apr 23, 2018 10:19 am
Ill be at the 2 stroke extravaganza on the 29th and you'll find me at Rogers both (Wicked Motorsports Atv). He did an amazing job on the motor.
Zedixe13
#11 Post by Zedixe13 » Mon Apr 23, 2018 10:31 am
Copy and paste the address of your pic and slide it between
No space.
Nice bike .
DFB
#12 Post by DFB » Mon Apr 23, 2018 12:01 pm
Thanks for posting that shot Zedixe. I get copie and paste but slide it in between is banana to me.
I missed the boat on computer skills.
#13 Post by Smoker » Mon Apr 23, 2018 12:30 pm
Got it. Nice arm.
Was taking a serious look, but I prefer aluminum.
Good luck with your project!
DFB
#14 Post by DFB » Tue Apr 24, 2018 10:41 pm
Smoker, FYI I have this swing arm drawn in Solid works. The production is laser cut and assembled tacked and welded. It can also be produced in Aluminium in the same process.
#15 Post by Smoker » Wed Apr 25, 2018 12:32 am
DFB wrote:Smoker, FYI I have this swing arm drawn in Solid works. The production is laser cut and assembled tacked and welded. It can also be produced in Aluminium in the same process.
Will need to look some more and ask more questions.
But, I'm interested again! :smt023
