New LC project
nokturnal
Re: New LC project
#16 Post by nokturnal » Tue Aug 07, 2018 3:47 pm
delete... crisis averted
:smt017
nokturnal
Re: New LC project
#17 Post by nokturnal » Wed Aug 08, 2018 10:11 am
Found the lights...
Had to get the wiring diagram and multi meter out...
:smt017
nokturnal
Re: New LC project
#18 Post by nokturnal » Sun Aug 12, 2018 10:59 pm
and now this... soooo close.
http://www.rzrd500.com/phpBB3/viewtopic.php?f=3&t=15560" onclick="window.open(this.href);return false;
:smt017
nokturnal
Re: New LC project
#19 Post by nokturnal » Wed Aug 15, 2018 11:23 am
Found the electrical problem that was dimming the headlight, and glowing the signals was a bad ground to the headlight. Separate ground run to frame and all is good now.
I'll dig into the harness in due time to fix the problem at the source.
Bike is safetied now, and insured. On the road ish... now running into some fuelling problems... not sure if its the jetting or not. Investigations pending. Checking on jetting, tank vent, compression etc. It's falling flat at 6000, same old story...
:smt017
nokturnal
Re: New LC project
#20 Post by nokturnal » Wed Aug 15, 2018 11:51 am
Interestingly when I took the stator cover off to check the sprocket, it was very clean. Cleaner than ANY used RD/RZ I have bought...
:smt017
nokturnal
Re: New LC project
#21 Post by nokturnal » Thu Aug 16, 2018 9:12 am
New problems:
1. oil leak from right side. Enough to put a coating on the leading edge of the side panel, some on the pipe, and a drop or two on the rear wheel (can see the "fling")
2. bunged up tacho, not reading right
3. that rear over-size tire is 18 years old
4. new ground issue with signals
Hopefully will have 3 of 4 sorted today... Need to ride the shit out of it this weekend.
:smt017
Hooligan
Re: New LC project
#22 Post by Hooligan » Thu Aug 16, 2018 3:39 pm
I would seriously caution you against riding an 18 yo tire. That is a recipe for disaster.
OldTZracer
Re: New LC project
#23 Post by OldTZracer » Fri Aug 17, 2018 2:21 am
Did you get a LH switch sorted out? It has a ground running to the main harness as well...
nokturnal
Re: New LC project
#24 Post by nokturnal » Fri Aug 17, 2018 7:05 am
new tires are on.
i did get the switch sorted. it's between that and the signals... will take a look this morning.
:smt017
nokturnal
Re: New LC project
#25 Post by nokturnal » Sat Aug 18, 2018 10:11 pm
She’s leaking. Electrically challenged. Some sort of front end weirdness.
I’ve put about 500km on it in the last day...
RuZty joined yesterday for a rip. Sweetest handling RZ I’ve been on.
:smt017
Re: New LC project
#26 Post by hondaror » Sun Aug 19, 2018 12:57 am
That yellow LC. Memories. The RZ looks great Russ!
OldTZracer
Re: New LC project
#27 Post by OldTZracer » Sun Aug 19, 2018 12:04 pm
I think the electrical issues are due to a sticker imbalance. There is not enough blue on the RH side...
Hooligan
Re: New LC project
#28 Post by Hooligan » Mon Aug 20, 2018 12:35 am
RuZty wrote:I have a rectangular tailight that I think is from an RZ500 that might be close/same. I can probably sort out a usable left switch from something else that will get you by as well.
Turns out that the Suzuki DRZ 400 tail light is exactly the same as the LC tail light. And I don't mean close, it is EXACTLY the same part number.
nokturnal
Re: New LC project
#29 Post by nokturnal » Mon Aug 20, 2018 9:53 am
OldTZracer wrote:I think the electrical issues are due to a sticker imbalance. There is not enough blue on the RH side...
Possible. They did their primary job though, which was to distract from/cover the dings and scratches in the tank.
:smt017
nokturnal
Re: New LC project
#30 Post by nokturnal » Mon Aug 20, 2018 10:08 am
I am back from my weekend riding trip... The bike functionally did about 800 problem-free twisty-road crank-stressing km (depending on your definitions), like a mf champ.
Electrics are still F'ed. I took apart the gauges in the hotel, redid the ground in that harness, but they are still not working properly. The tach problem is electrical too I think (even though its mechanical drive), as I believe it works at a standstill, but not while riding, which is the same with the signal idiot lights and temp guage. There is another bad ground somewhere.
There was a small oil leak, I believe at the front case joint, which was a consistent few drops per ride all weekend, enough to spray in the wind on to the carb, case and leading edge of the side cover, but not on me thankfully. This will hopefully be fixed when I do the clutch soon, I had some rare slippage at HIGH rpm.
The new battery-tender lithium battery, did not explode, catch fire, or otherwise, and worked as expected all weekend, even with a questionable electrical system.
Front end is making weird noises at slow speed (maybe I can only hear them at slow speed)... I think it may be the cable drive for the speedo. Sounds like a cable slapping a fender, a sort of clunkyness, but that is defo not what is happening.
:smt029
:smt017
