kobra's 1985 RZ350NC2 basket case restoration
Hooligan
Re: New project '85 RZ350 NC2
#61 Post by Hooligan » Thu Nov 01, 2018 11:58 pm
I've got a set of pipes that look just like those expansion chambers but they have Factory cans on them. Some kind of parts swapping went on there I think.
kobra
#62 Post by kobra » Fri Nov 02, 2018 12:06 am
Hooligan wrote:I've got a set of pipes that look just like those expansion chambers but they have Factory cans on them. Some kind of parts swapping went on there I think.
Seems to me that designing a chamber is a rather complex science. So maybe one or two teams did the work to figure out what works well and other companies copied them...
Hooligan
#63 Post by Hooligan » Fri Nov 02, 2018 12:41 am
The hangers on mine are exactly the same as the ones in the pics above.
ZedSledder
#64 Post by ZedSledder » Fri Nov 02, 2018 1:44 am
There is a DG mod out there. It increases the stinger with 1” pipe then little silencers are grafted on. Thats what I’ll do to mine forsure.
Cheers?
kobra
#65 Post by kobra » Fri Nov 02, 2018 3:00 am
ZedSledder wrote:There is a DG mod out there. It increases the stinger with 1” pipe then little silencers are grafted on. Thats what I’ll do to mine forsure.
Cheers?
I looked into this and all I found was people modding the RD400 pipes so that it has a stinger. Is there an RZ version mod too?
bikemad
#66 Post by bikemad » Fri Nov 02, 2018 7:14 pm
I have a brand new, unstamped rz250/350 top crankcase. I know that the story goes that they are machined in upper and lower cases assembled, but I have tried this top section on a spare set of cases lower crankcase and there are no steps/lips where they two halves meet. If you are interested PM me but I'm in West Australia.
kobra
#67 Post by kobra » Fri Nov 02, 2018 8:22 pm
bikemad wrote:I have a brand new, unstamped rz250/350 top crankcase. I know that the story goes that they are machined in upper and lower cases assembled, but I have tried this top section on a spare set of cases lower crankcase and there are no steps/lips where they two halves meet. If you are interested PM me but I'm in West Australia.
There are two dowel pins that align the top and bottom case halves. I believe they are assembled this way, and then "line bored" so that they line up perfectly. Someone correct me if I'm wrong.
However... I might be interested in it for another purpose. PM inbound.
brrrappp
#68 Post by brrrappp » Sat Nov 03, 2018 1:16 am
The matching of the halves is pretty important since all the shafts, crank and transmission, need to line up to get good bearing life and tight oil seal. However, I know of several people that have hacked together unmatched case halves on two-stoke snowmobiles and lived to tell about it. I have replaced a single case-half on vertically split dirt bikes several times and never had a problem.
Finally, as suggested by a previous post, you could have a good welder repair the broken case upper using a piece cut from a used/junk upper from another bike.
kobra
#69 Post by kobra » Sat Nov 03, 2018 2:19 pm
brrrappp wrote: Finally, as suggested by a previous post, you could have a good welder repair the broken case upper using a piece cut from a used/junk upper from another bike.
That's the plan more or less.
two-stroke-brit
#70 Post by two-stroke-brit » Sat Nov 03, 2018 7:41 pm
thats what i did.
once painted black you cant tell. :smt023
kobra
#71 Post by kobra » Sat Nov 10, 2018 3:12 am
Teaser shot!
kobra
#72 Post by kobra » Sun Nov 11, 2018 5:54 pm
I've got one more request. Would someone mind taking some nice detailed photos of the engine case in this area where the chain broke mine? So I can see what the profile looks like, the general shape, any clearances it might need (sprocket, clutch arm, etc). Hopefully won't be too much of a hassle, but would be super helpful. The higher the resolution the better.
tacky1
#73 Post by tacky1 » Sun Nov 11, 2018 9:52 pm
PM Sent....
#74 Post by RuZty » Sun Nov 11, 2018 10:09 pm
You made a chocolate engine for Christmas!
kobra wrote:Teaser shot!
kobra
#75 Post by kobra » Mon Nov 12, 2018 2:46 am
tacky1 to the rescue! Got the pics I need.
