My Blinged-Out RZ Project
Re: My Blinged-Out RZ Project
#2011 Post by Smoker » Mon Sep 19, 2016 1:37 pm
Drew up brackets to mount carbon fiber panels.
I previously cut and tacked in some primitive triangle mounts/gussets to the frame. They didn't look good and the panel holes were too close to the corners, so I chopped them out.
The new brackets are simple, but I want them to look good - so I'm not cutting them by hand. I think water-jet is the way to go, but never had it done before.
Need to find a water-jet place that will cut a small order (about 12 brackets) from .09" 4130.
Please post or PM me if you have info on water-jetting.
#2012 Post by Smoker » Tue Sep 20, 2016 5:35 am
Panel bracket drawings sent for a quote.
Need 8, asked for 16 - just in case. :smt003
#2013 Post by Smoker » Tue Sep 20, 2016 5:38 pm
Water-jet order completed.
16 pieces, about $135 usd, 4130 included.
My contact also made a .dxf file of the bracket, but I can't open it on my phone.
#2014 Post by RuZty » Tue Sep 20, 2016 5:59 pm
You might be able to import it into OnShape and open it there, but I haven't tried myself.
#2015 Post by Smoker » Sun Sep 25, 2016 6:46 pm
RuZty wrote:You might be able to import it into OnShape and open it there, but I haven't tried myself.
Wasn't able to, but I tried.
It's okay, the brackets are already being cut.
#2016 Post by Smoker » Sun Sep 25, 2016 6:46 pm
The machined portion of the rear steering damper mount is done.
Haven't received it yet. Already got the 4130 tubing to make the base of the mount.
I'm gonna wait until the mount is welded in, before taking measurements for the titanium pin.
#2017 Post by Smoker » Sat Oct 01, 2016 12:19 am
Got a new idea today. Shirked all responsibilities and went with it.
Designed a one-off kickstarter using CNC cut billet aluminum, TiN coated titanium, and needle roller bearings.
Also designed an aluminum tool to help me get accurate measurements from the OEM kickstarter.
#2018 Post by RuZty » Sat Oct 01, 2016 8:40 pm
Smoker wrote:Got a new idea today. Shirked all responsibilities and went with it.
Those are the best days.
#2019 Post by Smoker » Wed Oct 05, 2016 2:20 pm
Looks like my crazy jig is going to work for holding the rear steering damper bracket.
Pretty much ready to tack and weld, but I'd like to do some other stuff at the same time.
Having a real problem with the steering lock. Can't figure a way to hold it on the head tube for welding. The placement has to be dead-on because the pin fits snugly on each side of the lock.
Been using wire, but it's not accurate enough and doesn't hold well. Haven't figured a way to clamp it, yet. Right now, trying to find out if a (cylinder) magnet on the inside of the head tube will hold it. Head tube is pretty thick, though.
#2020 Post by Smoker » Wed Oct 05, 2016 2:28 pm
Heard that the 4130 brackets for the electrical panels are done.
Really hoping they arrive this week.
Would like to get them cut to size and tacked in before the weekend.
Zombie
#2021 Post by Zombie » Wed Oct 05, 2016 5:30 pm
Aluminum, titanium, carbon fiber... every ounce counts! [smilie=punk.gif]
Z
#2022 Post by Smoker » Sat Oct 08, 2016 2:13 pm
Every time I hear a truck this morning, I go running outside. Nothing so far.
The water-jet cut brackets are supposed to arrive today.
Hoping to get 8 brackets trimmed, fitted and tacked in by tonight. We'll see.
evan_calgary
#2023 Post by evan_calgary » Sat Oct 08, 2016 2:54 pm
Smoker, just went through most of the pages of you Aprilia build this am as I was being lazy. very cool. Only thing missing is complete bike pictures (which I know you don't do)!
#2024 Post by Smoker » Sat Oct 08, 2016 3:20 pm
evan_calgary wrote:Smoker, just went through most of the pages of you Aprilia build this am as I was being lazy. very cool. Only thing missing is complete bike pictures (which I know you don't do)!
I get asked for full bike pics a lot.
I guess I'm just different than most builders. [smilie=dunno.gif]
There's no complete bike, or even a partial bike. I don't keep the completed parts on the bike. I keep them in boxes because I don't want them to get damaged while I'm working on other stuff. After all the parts are done, they need to come off the bike anyway, so the frame can be painted or powder coated.
Right now, this bike is a bare frame with the jig for the steering damper mount on it. That's it. Plus, I'm still welding brackets onto the frame. Easy to understand why I don't want any nice parts around.
I'd be happy to post those kind of pics, if I could.
#2025 Post by Smoker » Sun Oct 09, 2016 7:31 am
Water-jet brackets vs. caveman brackets.
Go under the front of the tank, in the 4 corners. Caveman corner to center = 0.625". Water-jet corner to center = 1.250". Still need to cut angles on the ends to fit.
I thought corner brackets would work for the panel under the rear of the tank- but the carb cable adjusters are in the way. So, I'm going to cut and weld 2 brackets together and mount them straight across. Will look better this way because the frame braces on either side go straight across, as well. The brackets go on the center of the tubes, not on top.
