another rz/fz/fzr
Re: another rz/fz/fzr
#106 Post by Smoker » Thu May 24, 2018 2:04 am
kpke wrote:I should post this in body parts also.
And I should have asked this before I started hacking.
Has anyone deflapped and opened the fuel filler hole on a US fuel tank?
How did you do it?
Pretty sure I used a chisel or drift. Just tapped on it all around, and it fell into the tank. Leaves a nice clean inner hole where it's pressed in.
To get the piece out, I think I reached in and squished it with a pliers, or maybe cut it with a dykes.
Was less than a 5 minute job.
Here's a pic for you:
kpke
#107 Post by kpke » Thu May 24, 2018 10:30 am
Thanks Smoker! (I knew I should have asked first :smt009 )
That would be much quicker, simpler, cleaner, smarter....
Maybe I will "fix" this one now :smt047
kpke
#108 Post by kpke » Sat May 26, 2018 10:35 pm
I tried to pound that "extra" filler part out but didn't want to hit too hard. It didn't want to fall out easily so I left it as is.
The tank has been treated with Metal Rescue and looks fantastic inside.
Here is a before and after of the fuse block.
Lugs are crimped, soldered, then shrink tube.
There are 2 extra fuse positions so I'll probably add a whole bunch of LED accents and then a stereo system with subwoofer :smt044
Or maybe just an R6 fan. :smt045
#109 Post by hondaror » Sun May 27, 2018 3:18 am
Ken, what's that fuse box from?
kpke
#110 Post by kpke » Sun May 27, 2018 11:25 am
I just searched amazon order history and found one that I returned and one I modified, did not use, so couldn't return. Did not find this one so I suspect it came from Oreillys or Autozone??? It's pretty nice and and actually has an oring seal in the lid.
This one is on 2 other bikes purchased from auto parts store. Sorry for the extra large pic.
waltmil
#111 Post by waltmil » Sun May 27, 2018 6:44 pm
I cringe at all those bare electrical connectors. Can't you find any heat shrink?
kpke
#112 Post by kpke » Wed May 30, 2018 12:40 am
I bought this china tach years and years ago. I wasn't too sure I would use it but got it temporarily wired up and it actually looks pretty good, better than I thought it would. I have to decide if I want to complete the install of the thing or splurge on another KOSO. :smt017
#113 Post by hondaror » Thu May 31, 2018 4:04 am
That one is interesting.
kpke
#114 Post by kpke » Thu May 31, 2018 11:14 am
Yes, we will see.
Does anyone know where I can pick up a tach signal on the RZ350? For a US 84 or 85 bike.
I need to test this unit on a running bike before I go through the effort of permanently installing it on this bike.
Thanks.
Yellow and Black RZ
#115 Post by Yellow and Black RZ » Thu May 31, 2018 11:20 am
I followed smurphs how to for an R1 gauge cluster.
Tachometer
Find the W/G wire that comes out of the wiring harnes from the flywheel on the RZ. There is a connector with both W/R and W/G wires right where it joins the main harness.
Splice into the W/G wire and connect it to the Y/B wire on the R1 harness.
viewtopic.php?f=3&t=1289" onclick="window.open(this.href);return false;
'85 RRZ350 - Hacked.
kpke
#116 Post by kpke » Thu May 31, 2018 5:20 pm
Thanks yellow and black. :smt023
I'll plug this thing in to the ugly bike and see if makes the tach do it's thing.
Yellow and Black RZ
#117 Post by Yellow and Black RZ » Fri Jun 01, 2018 3:50 pm
kpke wrote:Thanks yellow and black. :smt023
:smt023
Loving the project. Inspiring to say the least. Appreciate your taking the time to post progress and pics.
addicted to relics
#118 Post by addicted to relics » Thu Sep 13, 2018 8:59 pm
where you get them fork seals dust boots? I ordered the regular ones from all balls (shit balls) and they came with the us version witch I have installed anyway and kinda works as well but don't look as good.
got a Canadian 85 as well and rebuilding it, not to your standards just as a lighweight functional beater bike
good job btw
kpke
#119 Post by kpke » Fri Sep 14, 2018 10:39 am
This bike has FZR forks.
If you purchased parts for a stock US RZ350 you will get the taller dust boots that came on these bikes.
kpke
#120 Post by kpke » Thu Oct 03, 2019 12:39 am
Hoping to get back to this project (again) after another lull.
Oil lines hooked up.
