another rz/fz/fzr
RZResurection
Re: another rz/fz/fzr
#76 Post by RZResurection » Mon May 11, 2015 4:53 am
Yes, they do!!
Jeff
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Milled Head (0.020")
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
seahorse
#77 Post by seahorse » Tue May 12, 2015 6:30 am
Just read this nice project.
Re you reed sealing issue, recently on a build I had an issue with sealing the reeds, when I soon realised that I had inadvertently swapped out the bolts with new Allen head bolts that were a fraction to long and bottoming out before they were doing the job of compressing the gasket face on the reed block? Might be worth checking.
81Rd350lc resto 2016
81 Rd250lc resto 2017
1999 ZRX 1100
peterz84
#78 Post by peterz84 » Tue May 12, 2015 10:29 am
Nice job Ken :smt023 Really digging the black wheels, swingarm... I have a stockish Y/B with the same treatment. Cant beat black.
Pete
expat
#79 Post by expat » Tue May 12, 2015 11:29 am
peterz84 wrote:Nice job Ken :smt023 Really digging the black wheels, swingarm... I have a stockish Y/B with the same treatment. Cant beat black.
Pete
Pete, you need some of those nice rear sets on that bike!! :smt023
85 RZ350
88 YSR50
82 RD350LC (Current project)
97 Honda RS125 (race bike #1)
89 RGV250 VJ21
85 RG500
85 RZ350 Hybrid
86 GSXR750
kpke
#80 Post by kpke » Tue May 12, 2015 11:33 am
Pete
Thanks for the compliments guys. I should be able to get back to working on this bike soon.
Hey Pete, when are you going to replace the junkie rear sets on that yellow/black? :smt044
I do like your parking place for the bike. :smt023
If I get any more they will have to move into the house. Maybe I will get my better half an apartment to live in :smt047
Oh wait, I will have to change those plans because I will go hungry :smt042 Put another building in the backyard perhaps???
peterz84
#81 Post by peterz84 » Tue May 12, 2015 12:35 pm
Ken, my rearsets are on the way right now from T12 :smt023
I find that a steady rotation of bedroom decorations helps ease the sting a bit for the Mrs. :smt003
Annnnnnd, I own a grill, I wont starve :smt003 :smt003
Hell, if we gotta deal with towels with flowers on them, a zillion scented candles, and "experimental recipe" dinners....
(now, if I can only swap out the French door in the bedroom to an overhead...)
Pete
kpke
#82 Post by kpke » Sat Mar 05, 2016 12:09 am
After about four months I got these 2 radiators back from the welder dude at work. Test fit the one for this bike and it fits perfect now. Have not test fit the other one on to the TZRRZ350. I am now cutting the blue silicone hoses to get them to fit properly. Need to order no cut hose clamps from McMaster Carr.
The JL side by side pipes on this bike may come off in place of JL GP pipes. Hmmm, I thought I had pics of this bike with pipes mounted. I'll have to take more.
Before
After. There is a big, big difference in the location of the pin.
#83 Post by Smoker » Sat Mar 05, 2016 4:57 am
Nice fix on the radiators.
I've got one that needs the same thing. :smt012
kpke
#84 Post by kpke » Sun Mar 06, 2016 2:03 am
Blue hoses all cut and fitted.
This was posted in the rear set thread but I will post here for reference.
I used these ebay rod ends. Be forewarned they are China parts so you may die if use them.
4pcs 6mm Female Rod End 2 Right and 2 Left Hand Metric Threaded Joint Bearing
http://www.ebay.com/itm/271036141242?ru ... 26_rdc%3D1
Ordered these rods
FAST FROM THE PAST
205MM AND 225MM
M/F connecting rods
Currently have the 205mm installed. The longer one would be used if I adjust the rear sets back further.
Shifter knuckle is 2003 R6.
Also note the pressure switch at the banjo fitting.
kpke
#85 Post by kpke » Thu Mar 10, 2016 11:43 pm
A bunch of McMaster Carr stuff arrived yesterday including the no-cut clamps for the silicone hoses. But I fucked up on the size so the correct ones are on the way.
The Venhill brake lines arrived yesterday.
But I fucked up on the banjo bolts and ordered fine thread, which the new brembo is and I don't need because I have a fine pitch pressure/banjo there, instead of coarse thread which is needed every where else. I have emailed the rep and will trade for the correct ones.
2 for 2 on these orders. Fucking idiot. :smt013
BTW, this is the second time I screwed up on a McMaster Carr order, called them to see about returning the parts, they credit my account for the incorrect parts and tell me to keep them, then they send me the correct parts I need. Very good company :smt023
kpke
#86 Post by kpke » Sat Apr 09, 2016 9:36 pm
A small update.
The front master cylinder had a good feel to it, but since the bike has a brand new rear MC, I decided to rebuild it. After taking it apart, I am sure it would have worked fine before the rebuild. There was a little bit of crud in there so better off I am sure.
Rebuilt front master cylinder with Yamaha rebuild kit for FZR600 36Y-W0041-00
Brake lines front and rear are now installed.
All the hose are now installed and clamped with proper clamps.
South_Oz
#87 Post by South_Oz » Sun Apr 10, 2016 6:42 am
http://www.ebay.com/itm/271036141242?ru ... 26_rdc%3D1" onclick="window.open(this.href);return false;
I would put a washer on the bolt to stop the rod ends falling off in case of a failure.
kpke wrote:Blue hoses all cut and fitted.
Dave
RZ 250 85 (Waiting)
RZ 250 85 (Parts)
BMW R1100S 99 (Its Red)
BMW R1200GS (Its BIG)
L.B
#88 Post by L.B » Sun Apr 10, 2016 8:13 am
Now i always thought the blue hoses suited the rz lol....
Very nice build up,its always a cool feeling bolting on new go fast bits n parts.
Where did you find the gear selector mount? The splined cast peice? That come with the rear sets?
kpke
#89 Post by kpke » Mon Apr 11, 2016 11:35 am
Do you mean put something like a fender washer underneath the screw head to prevent the rod and from sliding all the way out (in the event it becomes 2 pieces rather than 1)? :smt017
South_Oz wrote:http://www.ebay.com/itm/271036141242?ru ... 26_rdc%3D1
Dave
kpke
#90 Post by kpke » Mon Apr 11, 2016 11:39 am
Thank you for the compliments.
The shifter part did not come with the rear sets.
It came off of a 2005 R6 that I happened to have left over from a track bike part out.
L.B wrote:Now i always thought the blue hoses suited the rz lol....
