Sacrificial Lamb
wolfman
Re: Sacrificial Lamb
#286 Post by wolfman » Mon Jul 11, 2016 5:32 pm
Still keeping busy eh ?
It's tough to sit still man I know.
I'm out on disability because of my vision so no work for me.
Well no more high speed aluminum tubing relocation for me.
I'm still working though :smt005
Good to see the post
Tarozzi fork brace
#287 Post by Smoker » Tue Jul 12, 2016 2:12 pm
wolfman wrote:I'm out on disability because of my vision so no work for me.
Glad you can still work on bikes!
A few small parts arrived.
Got the kicker powder coated and rebuilt.
#288 Post by Smoker » Wed Jul 13, 2016 9:34 am
Rebuilt the rear caliper with new pistons, seals, bleed screw and hardware.
Needed it bad. Had to scrape lots of crusty crap out of the seal grooves.
Just noticing those OEM chain adjusters need an upgrade.
#289 Post by Smoker » Sat Jul 16, 2016 10:42 am
Plugged in all the OEM electrical parts to make sure everything still works. Mostly good. Need to check the neutral switch and oil level sender. Also need to rewire the tail light and add rear turn signals.
Was able to figure out about half the OEM dash wiring using a test light. The wiring diagram I have is from an L model and isn't exactly the same as my N model bike.
I think the best way to proceed is to disconnect the OEM dash and buy matching wire connectors, so I can test the new dash without cutting the OEM harness (yet).
If the new dash works, I'll need to cut about 2 feet off the OEM harness and do some other creative wiring. Not looking forward to that. Also need to wire the ignition switch into the new location.
Searching for a good place that sells the OEM type connectors. Already ordered a new AGM type battery. Was going to go for a LiFePo4, but saw too many pics of burned up batteries. Not reliable enough for a daily bike.
Also pretty sure I'm not using those headlights I bought. Just don't trust them in the rain. Not really sure what headlight to go with. The forks are narrow, so I'm looking at motard and mini stuff.
wolfman
#290 Post by wolfman » Tue Jul 19, 2016 1:49 am
I've been wrenching too much lately, I want to ride the damn things.
the rebuilt kicker should be noise free now, at least mine was.
Someone mentioned radio shack had the connectors.
How are you liking the conti attack 2's ?
I'm on my last set of avons and will be going to those next.
I see you used socket head screws on the caliper mount.
The hollow r6/r1 bolts work too and are cheap on fleabay.
:smt026
Tarozzi fork brace
#291 Post by Smoker » Tue Jul 19, 2016 8:40 am
One of my new Contis is WAY out of balance and required a shitload of weights on the rim. :smt011
Got this coming soon. Never seen one of these on an RZ.
Needs some yellow paint and maybe a custom sticker to match the OEM sticker on the tail.
wolfman
#292 Post by wolfman » Wed Jul 20, 2016 12:22 am
Yeah, tires can be love hate for sure.
Nice lite, can't wait to see it on the bike.
Tarozzi fork brace
#293 Post by Smoker » Fri Jul 22, 2016 11:49 pm
Nearly impossible for me to order parts without some problem.
Got the new windscreen. Screw missing front and center. I don't have a matching screw, of course.
wolfman
#294 Post by wolfman » Sat Jul 23, 2016 10:45 am
Nothing is ever easy is it.
I always have the, "nice cake but you frosted it with shit!" Saying in the que.
just for such an occasion.
Tarozzi fork brace
#295 Post by Smoker » Sun Jul 24, 2016 7:51 am
Battery arrived. Still waiting on wire terminals.
Plenty of other stuff to work on.
waltmil
#296 Post by waltmil » Mon Jul 25, 2016 6:49 am
Gee Smoker, when I commented on that some time ago you said the wheel was out of balance.
#297 Post by Smoker » Mon Jul 25, 2016 8:21 am
waltmil wrote:Gee Smoker, when I commented on that some time ago you said the wheel was out of balance.
Lies, I say!!! :smt018
I searched this thread and your post history - and have no idea what you're referring to.
waltmil
#298 Post by waltmil » Mon Jul 25, 2016 8:41 pm
Well Hillary, perhaps you should check your old school rz350 build post dated Sep 17, 2014. Hondaror and I both commented about the amount of weight.
Questo vecchio rz
#299 Post by Questo vecchio rz » Mon Jul 25, 2016 11:30 pm
waltmil wrote:Well Hillary, perhaps you should check your old school rz350 build post dated Sep 17, 2014. Hondaror and I both commented about the amount of weight.
[/quote]
Have you balanced the wheel in question without a tire? Could be your wheel.[/quote]
waltmil wrote:That does possibly open up some more options but I've never been a Conti fan. Judging by the lead you have on the rim they may still have construction issues. I think I have about a tenth of that on my BT45s.
Smoker wrote:I'm saying - it's definitely the wheel. :smt023
AFTER A THOUROGH INVESTIGATION BY THE F.B.I , EVEN THOUGH IT MIGHT READ AS DAMNING EVIDENCE, WE FEEL THERE ARE NO GROUNDS FOR ANY PROSECUTION OF ANY KIND OF ANY WRONGDOING WHATSOEVER.
SMOKER WILL BE FORUM PRESIDENT ONE DAY. ITS NOT LIKE HE "HIT HIS HEAD"...LOL
waltmil
#300 Post by waltmil » Tue Jul 26, 2016 6:25 am
And as President he can pardon himself.
