Finally 99% Done..Hybrid..(RZ350,R1,R6,Z1000,Honda,Aprilia)
Well it has been almost 2 years and the project has almost been completed..
Here is a brief run down on what i have done..
Chassis
-1983 RZ350 Frame
-Removed the RZ350 rear sub frame
-Reinforced the head stock and the swing arm area
-Built the shock support
-Aprilia RS250 Rear swing arm
-06-07 R6 rear sub frame
-Aprilia Tuono Handle bar and risers
-Aprilia Tuono kick stand
-99-01 R1 vortex rear sets
Suspension
-99 R1 front end
-06-07 CBR1000RR rear shock
-Custom dog bones
-Aprilia RS250 relay arm
-Custom bracket to mount relay arm
Wheels,Brakes
-99 R1 front wheel,blue dot brake caliper(Apex braided Lines)
-99-02 R6 rear wheel,cush drive ,rear brake rotor and caliper (Apex braided Lines)
-Tires Front...120/70/17
Rear....180/55/17
Motor
-1UA RZ350 Motor
-Coolhead with 20cc domes
-Boost Bottle
-UNI pods
-RZ500 Kick start lever
-Clear clutch cover
-Custom water pump cover
-1UA PJ carbs
-Boyesen 2 stage reeds
Body Work
-99 R1 front fender
-99-02 Gas tank (Modified to fit frame) Oil tank(custom made aluminum) mounted in the front were air box would be)(pop up oil cap with r1 oil level sensor (credit goes to gpaddict for his oil level sensor idea..:)) Quick release front tank mount
-06-07 R6 rear tail with solo seat( undertail modified with all passenger and key holes filled)
-03-06 Kawasaki Z1000 front fairing
-99 and 06 R6 seat made into one
MISC..
-99 R1 gauges
-Factory pipe product exhaust pipes made to fit
-01 FZ1 Blue Paint.(Painted by me in my shed..lol)
-RDLC Crazy Front brake reservior and clutch window frame
-Brian's clutch cover gasket and bolts
-Capacitor for battery
-Custom offset front sprocket
-03 ZX6rr speed sensor
-MAKE IT ALL FIT...LOL
Things left to do...
-Larger Pilot jets
-GM hei module ( to fix r1 tach)
-Tuning fork emblems on tank)
-Final tweaking
I am sure i am missing things....will add when i remember..lol
Chassis
-1983 RZ350 Frame
Suspension
-99 R1 front end
-Custom dog bones
Wheels,Brakes
Rear....180/55/17
Motor
-1UA RZ350 Motor
-Boost Bottle
-UNI pods
-Clear clutch cover
-1UA PJ carbs
Body Work
-99 R1 front fender
MISC..
-99 R1 gauges
-Larger Pilot jets
-Final tweaking
- aaronmvrider
Strange, mines wired that way & runs perfect
Yes i seen that in the how to section....
i even went and traced the wires on the wiring diagram and it looks like it should work..( tach grey wire to ypvs b/y wirer from the cdi)..but i did not like what it did That why i thought i would try the gm hei module..
The tach does not like to run to well or at all off a capacitor (bat pac)
Everything else seems to work well on the gauges.....just have to get the tach figured out
Thxs for all the comments guys..
