Yamaha SZR 660 conversion to 350 YPVS - ( TZ250 replica )
Ricino
Re: Yamaha SZR 660 conversion to 350 YPVS - ( TZ250 replica
#31 Post by Ricino » Sun Sep 15, 2013 2:21 pm
Hello, Rob
Too bad to read those scary news, but glad to know you're ready to fix things and that you intend to arrange all those nice mods. It would also be nice if you increased the silencers' angle; those TSA pipes will look much better. I've been designing some new front mounts, not ready though. Will post some pics with the mockup, before cutting some alloy plates. You're lucky to own a 4DL, it is a much easier base to work with than the very asymmetrical SZR (4SU)
I'll be very interested to follow your build thread, so please keep us informed!
Best wishes,
Patricio
KennyBarroz
#32 Post by KennyBarroz » Sun Sep 15, 2013 3:40 pm
Want some more pictures on the chassi build please :)
How much different is the SZR and TZR frame?
RD350 F2 -87: SETUP :
Stock 65mm barrels, TSS YPVS kit, 0,9squish, Vforce3 reeds, stock intake for Vforce3 reeds, 28mm PWK custom made for oilpump and vacuum line, jets 120/40, modified airbox, Zeeltronic PCDI-10V - Custom curve
tzr350
#33 Post by tzr350 » Sun Sep 15, 2013 3:55 pm
The szr frame is a bit wider by around 20mm and has mounts that are in the way so they are usually cut off.
Ricino im having the exhausts altered too to match the angle of the subframe fairing.
Ricino
#34 Post by Ricino » Wed Sep 18, 2013 9:20 am
Glad you´re taking the crash as an opportunity.
Here are some pics of the front mounts design (remember that the rear mount is already finished).
Lots of eyeballing, testing, measuring and so on. Very challenging and enjoyable build!
It is a fully manual process, first using thick coloured paper and then some kind of light cardboard made of two sheets of paper and a foam core. It is a nice material to mock up the future alloy plates, because it is rigid, easy to cut, and it has the same thickness as the final plates (5 mm.)
I´m not going to weld the mounts straight onto the frame. First I´m going to cut some smaller twin plates (one pair for each mount), then will weld them to the frame as a base to fasten the bigger plates with screws and bolts (thus working as a very rigid sandwich). This way the engine will be easier to be serviced, and also makes things easier for me to precisely position the engine in its final place and angle.
KennyBarroz
#35 Post by KennyBarroz » Wed Sep 18, 2013 9:32 am
Wow great job! Really! But there looks to be small space for carb adjustments? :)
Lile idea of the mountings! Great work and keep them pictures posted!
RZResurection
#36 Post by RZResurection » Thu Sep 19, 2013 10:12 am
I like how you are doing the mounts. Very professional looking.
If you have trouble with space to make carb adjustments, you can build some special tools ;) 'If there is will - there is a way'
I'm watching with a lot of interest. Keep up the good work my friend.
Jeff
87 Canadian 1WV
OEM Pipes
Gutted Airbox
VF4 Reeds
Milled Head (0.020")
Main 240
Pilot 27.5
02 R1 Front End
84 FJ1100 Swingarm
Ricino
#37 Post by Ricino » Thu Sep 19, 2013 11:03 am
Thanks, guys!
I might drill some holes on the left mount for carb adjustments and also for the choke (installing an extension for the choke actuator, too)
RZResurection wrote: 'If there is will - there is a way'
This statement can't be more true!
tzr350
#38 Post by tzr350 » Fri Sep 20, 2013 1:01 pm
Ricino I may have a pair of kr1s carbs, pod filters, choke cables, choke lever and tick over cables from my bike if my fuel injection goes to plan but no for a few months. Let me know if your interested.
KennyBarroz
#39 Post by KennyBarroz » Fri Sep 20, 2013 1:17 pm
I have a pair of RGV250 (MIKUNI TM32mm)carbs if interested?
Ricino
#40 Post by Ricino » Fri Sep 20, 2013 1:44 pm
Thanks, Kenny but I prefer some PWK.
Rob, PM sent.
KennyBarroz
#41 Post by KennyBarroz » Sun Oct 20, 2013 6:52 pm
How is the project going?
Ricino
#42 Post by Ricino » Wed Jan 22, 2014 7:37 pm
Hello K.B. ,
Thanks for your interest and sorry it took me three months to answer, but for several reasons I had to put aside the project, until now.
Today I met a good friend who just started a project like mine, and we will work together to join forces in order to find some technical solutions and to make them come true. So, I hope to have this thread updated more often from now on!
PS. It is nice to see all the progress throughout the forum, as well as the new ones that have arrived.
KennyBarroz
#43 Post by KennyBarroz » Wed Jan 29, 2014 6:21 pm
Ricino wrote:Hello K.B. ,
There you are my friend! :smt038
This is good news! As long as you dont cut down on those great pictures. How much has been done to the project now?
This is what iam doing right now since you showed light into my tunnel!
Vin
#44 Post by Vin » Thu Jan 30, 2014 10:28 am
Hi Guy's,
My next project (when I get to it!) will be using the SZR rolling chassis and 350 motor that I have so look forward to see'ing your progress and look for tips :smt023
I'm still at the collecting bit's stage but see you have twin disc's Kenny, what bike does the extra calliper come from?
Bngt
#45 Post by Bngt » Thu Jan 30, 2014 10:35 am
Very inspiring.
I might have to do something similar. Kenny, are you planning for having these fairings as well? Do you know where to source them from?
I just had to repeat this picture!
F2 1986 project (ZX636R suspension)
F2 1987 The mule, test bench for tuning.
31K 1984 Donor
TZR 2MA 1986 Racer
TZR 2MA 1987 Stock
ZX10 1988 Cruiser
VTR 2005 (with CBRRR suspension, brakes and wheels)
Husaberg FS 570
GSX-R 1000 K5
