It is currently Sun Oct 21, 2018 4:20 pm
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Thu Nov 05, 2015 10:20 pm
A huge improvement, Excellent stopping power and a lot more feel, Great upgrade to the anemic RZ brakes...
PostPosted: Tue May 03, 2016 5:32 pm
Back in stock, Get them hot off the CNC.
http://www.tdrracing.com
www.tdrrz.com
PostPosted: Tue May 03, 2016 7:02 pm
Night & day improvement. Definitely NO need for bigger rotors...Unless your ego says otherwise!!!
Sent from my SM-G920P using Tapatalk
PostPosted: Thu Jun 09, 2016 9:49 am
These are also listed on EBAY as well. Same price.
www.tdrrz.com
PostPosted: Wed Jun 15, 2016 8:48 am
Back in stock.
www.tdrrz.com
PostPosted: Wed Jun 15, 2016 5:59 pm
I hope to order a set soon... Do the bolts to attach them come with them? If not what do yall use?
Tim Steele in Front Royal, VA
PostPosted: Wed Jun 15, 2016 6:20 pm
The bolts are not included. I will get the length and post it later. R1 caliper bolts work for the mounting bracket and R1 bolts for the caliper.
www.tdrrz.com
PostPosted: Wed Jun 15, 2016 6:52 pm
Thanks!
PostPosted: Sat Jun 18, 2016 1:45 pm
I am researching calipers and read from an unknown source that the gold dot calipers have aluminum pistons and the blue dots have steel. I also learned that r6 calipers 04 and earlier and r1 03 and earlier will fit the same. This conclusion leads me to my query. Gold or blue dot? Aluminum or steel pistons? I am leaning towards the gold dots as I am buying used and am concerned about corrosion....
Are there any disadvantages to the aluminiumn pistons?
PostPosted: Sat Jun 18, 2016 2:00 pm
If you bleed your Brake fluid once every riding season, corrosion won't be a problem. Brake fluid is hygroscopic therfore it absorbs moisture.
PostPosted: Sat Jun 18, 2016 3:01 pm
I am asking if there are any advantage or disadvantages to the aluminum pistons in brake calipers versus steel.
PostPosted: Sat Jun 18, 2016 3:30 pm
A little lighter i suspect.
PostPosted: Sat Jun 18, 2016 3:37 pm
PostPosted: Sat Jun 18, 2016 3:59 pm
Just make sure you keep the correct ratio of master to caliper size. I suggest using the matching R1/R6 master cylinder.
www.tdrrz.com
PostPosted: Sat Jun 18, 2016 6:08 pm
Thanks!
