It is currently Sun Oct 21, 2018 5:37 am
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Sat Jun 18, 2016 7:07 pm
I just ordered a set. Looking forward to getting them. Thanks Tony!
Tim Steele in Front Royal, VA
PostPosted: Sun Jun 19, 2016 10:04 am
http://www.ebay.com/itm/121848970686?_t ... EBIDX%3AIT
This vendor accepted my offer so I ended up with this set.
PostPosted: Sun Jun 19, 2016 8:14 pm
Looks good , Good price. Just need a master cylinder.
http://www.tdrracing.com
www.tdrrz.com
PostPosted: Wed Jun 22, 2016 1:04 am
Thanks!!!
PostPosted: Wed Jun 22, 2016 3:48 pm
Adapters arrived today. Thanks Tony!!
Lines and calipers arrived as well..just waiting on the bolts.
Making hay any way so no time for RZ wrenching...
PostPosted: Sun Jun 26, 2016 6:36 pm
Imagefree photo hosting
Done and done. Bled out in 10 minutes. Test ride complete. Stops just like the Phoenix with 2 fingers from 95 MPH..
The fit and finish on the TDR adapters is superb....Thanks TDR!!! Bolted right on and was able to use my existing braided lines. The difference is night and day. As Mark Haase said careful application is necessary. I will try the R1 master cylinder when it arrives but it certainly is rideable and way better than stock as is....
PostPosted: Sun Jun 26, 2016 6:48 pm
Use an FZ8 master cylinder if you want to keep your mirror, The R1 doesn't have a hole to mount the mirror. The FZ8 uses the same calipers, Brakes are superb..
PostPosted: Sun Jun 26, 2016 6:56 pm
I use bar ends. I bought an R1 master cylinder off ebay. It is yet to arrive...
PostPosted: Sun Jun 26, 2016 7:03 pm
Problem solved.. :)
PostPosted: Mon Jun 27, 2016 7:11 pm
Thanks!!!
PostPosted: Mon Jun 27, 2016 7:42 pm
thats handy to know for the future upgrade.
thanks mark
2004 BMW R1150RT
1989 FZR1000
1994 FZR1000
PostPosted: Tue Jun 28, 2016 7:03 pm
Imageimg host
Imagegif image hosting
R1 master cylinder installed and bled. I decided to use the existing master cylinder mount bracket for the reservoir in the absence of any other brackets.... I used a long allen head bolts and spaced the reservoir out a touch with m6 washers so it doesn't rub against
anything. I had a nice new piece of John Deere diesel injector hose that I installed after I decided the mounting for the reservoir and the original hose was too short...
It took about 10 minutes to bleed out. All thats left to do is rewire the pressure switch end to adapt it to the R1 switch and it will be test ride time. I will also be ordering a stock lever replacement for the blue lever that came on the mastercylinder so they match...I found it interesting that it came with a double banjo bolt so apparently the R1 didnt have a splitter and ran two lines side by side out of the master cylinder. I was able to bolt the braided line installed on the RZ with a little manuvering...
PostPosted: Wed Jun 29, 2016 11:54 am
Test ride complete... I am amazed at the brakes....
I wired up the brake light switch and after a short argument and a bit of dry lube said switch is functioning perfectly.
Done and done.
Imagefree image host
PostPosted: Wed Jun 29, 2016 3:58 pm
Imagefree picture hosting
PostPosted: Wed Jun 29, 2016 8:30 pm
should be a good ride now you are getting it sorted .
nothing like killer brakes to give you confidence.
nice work as always tim.
mark
2004 BMW R1150RT
1989 FZR1000
1994 FZR1000
cron
